이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Assess the damage and the amount of bent pins by gripping the CPU by the edges and peering down the straight rows of pins to check for abnormalities.
Check each row—from both directions—so you have a good idea of which areas you need to work on. For example, look down the pins north to south as well as east to west.
Gently slide the utility blade between two rows of pins.
If bent pins block the blade's path, gently bend them upright using the sharp corner of the blade, going one at a time.
Once the blade can make it down a full row, tilt the blade side to side to straighten the pins on each flanking row.
Rotate the CPU 90˚ and slide the blade down a row in the opposite direction.
As you push the blade along the row, rock it back and forth, straightening pins along the way.
이 단계에 사용된 도구:Tweezers$3.99-
If you're really in a pinch, you can modify a pair of tweezers to have a slightly curled tip.
Be careful using too much force—the long pencil body will give you more leverage than you realize.
On your motherboard, lift the socket locking arm out around the locking clip and up to its vertical position.
Match the corner of the CPU with a gold triangle to the corner of the motherboard socket that also has a triangle.
Grip the CPU by its edges and align it over the socket.
Lower the CPU into the socket, ensuring that all pins fall into their matching holes.
If the pins don't find their holes immediately, or if only one side goes in, remove the CPU and check its pins again.
Once the pins on your CPU are straight enough to allow it to be installed into the socket, close the locking arm by pulling it down, around the locking tab.
Without touching the CPU, repeat the locking/unlocking process on the socket four to five more times.
That's it! Close the socket's locking arm and proceed with your PC build.
다른 24명이 해당 안내서를 완성하였습니다.
댓글 14개
Thanks so much!
Ce tutoriel est aussi valable pour les sockets Intel à “matrice de pastilles” (Land Grid Array) sauf que dans le cas d’un socket LGA les pins à relever seront sur le socket plutôt que sur le processeur, mais le principe est le même, j’ai pu sauver une carte mère avec un socket LGA 1155 comme ça.
Exemple de socket LGA ou les pins sont bien visibles : https://upload.wikimedia.org/wikipedia/c...
Les pins sur les sockets sont très petits, mais avec une pincette de précision (visible dans ce tutoriel) comme celle d’iFixit c’est faisable.
It's a valuable guide for those who get into trouble with bent CPU pins.
I have encountered and dealt with such a problem several times. It's not an easy task.
This guide gives readers the knowledge and tool to fix the struggle problem. Especially, step-by-step instruction with clear photos will encourage readers to overcome the problem.
Thank U :) I’ll fix it.
using a razor blade is brilliant. worked perfectly
