주요 콘텐츠로 건너뛰기
How to Fix Bent Eyeglasses
필요한 것
  1. How to Fix Bent Eyeglasses, How to Fix Bent Eyeglasses: 1 단계, 이미지 2개 중 1개 How to Fix Bent Eyeglasses, How to Fix Bent Eyeglasses: 1 단계, 이미지 2개 중 2개
    • Hold the temple and the end-piece of the eyeglasses together so that the screw-holes are aligned.
    • On a flat surface, carefully place the 1.4 mm slotted screw in the screw-hole.
  2. How to Fix Bent Eyeglasses: 2 단계, 이미지 1개 중 1개
    • Use an eyeglasses screwdriver to screw the two pieces back together.
  3. How to Fix Bent Eyeglasses: 3 단계, 이미지 2개 중 1개 How to Fix Bent Eyeglasses: 3 단계, 이미지 2개 중 2개
    • On medium heat, blow a hairdryer onto the bent part of the glasses in order to make it more malleable.
    • Using too much heat or heating the glasses for too long can cause permanent damage to the lenses or frames.
  4. How to Fix Bent Eyeglasses: 4 단계, 이미지 2개 중 1개 How to Fix Bent Eyeglasses: 4 단계, 이미지 2개 중 2개
    • Gently bend the heated up piece until it appears straight again.
    • Bend the glasses lightly as not to snap or disfigure them further.
  5. How to Fix Bent Eyeglasses: 5 단계, 이미지 1개 중 1개
    • Place the glasses on a flat surface. All four bottom points should be touching the ground.
결승점
작성자
1다른 기여자 명과 함께
Ellington Jones
회원 가입일: 05/29/24
121 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 33
전체 시간: 834
