주요 콘텐츠로 건너뛰기
How to Fix Bicycle Foam Handlebar Grips
필요한 것
  1. How to Fix Bicycle Foam Handlebar Grips, How to Fix Bicycle Foam Handlebar Grips: 1 단계, 이미지 3개 중 1개 How to Fix Bicycle Foam Handlebar Grips, How to Fix Bicycle Foam Handlebar Grips: 1 단계, 이미지 3개 중 2개 How to Fix Bicycle Foam Handlebar Grips, How to Fix Bicycle Foam Handlebar Grips: 1 단계, 이미지 3개 중 3개
    • Assess the problem area on your bike's handlebars.
  2. How to Fix Bicycle Foam Handlebar Grips: 2 단계, 이미지 2개 중 1개 How to Fix Bicycle Foam Handlebar Grips: 2 단계, 이미지 2개 중 2개
    • Lightly sand down the handlebar with the sandpaper.
    • Continue to sand the handlebar until no more residue falls.
  3. How to Fix Bicycle Foam Handlebar Grips: 3 단계, 이미지 2개 중 1개 How to Fix Bicycle Foam Handlebar Grips: 3 단계, 이미지 2개 중 2개
    • Boil water in a pot.
    • Once the water reaches boiling temperature (212°F/100°C), dip a rag into the water.
    • Be careful when handling the rag after it has been taken out of the boiling water. Handling the rag too quickly can result in a burn.
    • Take the soaked rag and begin cleaning the handlebar by applying pressure and rubbing in a downwards motion.
  4. How to Fix Bicycle Foam Handlebar Grips: 4 단계, 이미지 2개 중 1개 How to Fix Bicycle Foam Handlebar Grips: 4 단계, 이미지 2개 중 2개
    • Press a new, clean rag tightly to the opening of the alcohol bottle.
    • Tip the bottle upside down quickly and soak the rag with the alcohol.
    • Once the rag is soaked, start cleaning the handlebar again. Continue to clean the handlebar until there is no more visible residue coming off.
  5. How to Fix Bicycle Foam Handlebar Grips: 5 단계, 이미지 2개 중 1개 How to Fix Bicycle Foam Handlebar Grips: 5 단계, 이미지 2개 중 2개
    • Finally, bring the water to a boil once more.
    • Dip a rag into the water and begin rubbing the handlebar for the last time. Clean vigorously until the handlebar is noticeably smoother and no longer crumbling with residue.
결론
Following these steps should result in handlebars that feel brand new!
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Katy Haas
회원 가입일: 04/28/17
125 평판
안내서 1개를 작성함
UC Davis, Team S1-G1, Coad Spring 2017 UC Davis, Team S1-G1, Coad Spring 2017 회원
UCD-COAD-S17S1G1
4 회원들
안내서 1개 작성
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 17
전체 시간: 5,797
