주요 콘텐츠로 건너뛰기
How to Fix Broken Crayons
필요한 것
  1. How to Fix Broken Crayons, How to Fix Broken Crayons: 1 단계, 이미지 3개 중 1개 How to Fix Broken Crayons, How to Fix Broken Crayons: 1 단계, 이미지 3개 중 2개 How to Fix Broken Crayons, How to Fix Broken Crayons: 1 단계, 이미지 3개 중 3개
    • Peel off the paper wrapper on all of the crayon pieces.
  2. How to Fix Broken Crayons: 2 단계, 이미지 3개 중 1개 How to Fix Broken Crayons: 2 단계, 이미지 3개 중 2개 How to Fix Broken Crayons: 2 단계, 이미지 3개 중 3개
    • Boil water to 212°F/100°C.
    • A kettle is recommended for more control when pouring.
  3. How to Fix Broken Crayons: 3 단계, 이미지 3개 중 1개 How to Fix Broken Crayons: 3 단계, 이미지 3개 중 2개 How to Fix Broken Crayons: 3 단계, 이미지 3개 중 3개
    • Cut a piece of aluminum foil about 6x2 inches.
    • Fold the 6 inch side of foil in half.
    • Fold up all four sides of the foil to create a thin rectangle, about 1 inch away from the edges.
  4. How to Fix Broken Crayons: 4 단계, 이미지 3개 중 1개 How to Fix Broken Crayons: 4 단계, 이미지 3개 중 2개 How to Fix Broken Crayons: 4 단계, 이미지 3개 중 3개
    • Pinch up the corners of the foil by following the folded creases made in the last step.
    • Repeat this step for all four corners.
  5. How to Fix Broken Crayons: 5 단계, 이미지 3개 중 1개 How to Fix Broken Crayons: 5 단계, 이미지 3개 중 2개 How to Fix Broken Crayons: 5 단계, 이미지 3개 중 3개
    • Insert the broken crayon pieces into the foil mold.
  6. How to Fix Broken Crayons: 6 단계, 이미지 3개 중 1개 How to Fix Broken Crayons: 6 단계, 이미지 3개 중 2개 How to Fix Broken Crayons: 6 단계, 이미지 3개 중 3개
    • Place mold into a heat-safe container.
    • While holding onto the mold, carefully pour in boiling water up to the rim of the mold.
    • Your mold may float in the water or tilt to one side while water is being poured.
    • Wait for the wax to fully melt.
    • Be careful when handling hot materials.
  7. How to Fix Broken Crayons: 7 단계, 이미지 3개 중 1개 How to Fix Broken Crayons: 7 단계, 이미지 3개 중 2개 How to Fix Broken Crayons: 7 단계, 이미지 3개 중 3개
    • Take the mold out of the water once cooled.
    • When wax has moderately hardened, loosen the sides of the foil from the wax.
    • Cut a corner of the foil mold and unwrap the crayon.
    • Leave the newly created crayon in a cool and dry area overnight to fully solidify before use.
결승점
작성자
3다른 기여자 명과 함께
Madeline Furtado
회원 가입일: 05/12/25
145 평판
안내서 1개를 작성함
UC Davis, Team 2-8, Whithaus Spring 2025 UC Davis, Team 2-8, Whithaus Spring 2025 회원
UCD-WHITHAUS-S25S2G8
3 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 41
전체 시간: 352
