주요 콘텐츠로 건너뛰기
How to Fix Broken Porch Entry Stairs
필요한 것
  1. How to Fix Broken Porch Entry Stairs, Stair treads and risers: 1 단계, 이미지 3개 중 1개 How to Fix Broken Porch Entry Stairs, Stair treads and risers: 1 단계, 이미지 3개 중 2개 How to Fix Broken Porch Entry Stairs, Stair treads and risers: 1 단계, 이미지 3개 중 3개
    • Use a pry bar to remove the pre-existing damaged wood pieces.
    • Start with the riser first.
    • Be mindful of possible rusted screws/nails.
  2. How to Fix Broken Porch Entry Stairs: 2 단계, 이미지 3개 중 1개 How to Fix Broken Porch Entry Stairs: 2 단계, 이미지 3개 중 2개 How to Fix Broken Porch Entry Stairs: 2 단계, 이미지 3개 중 3개
    • Remove the treads on the stairs.
  3. How to Fix Broken Porch Entry Stairs: 3 단계, 이미지 2개 중 1개 How to Fix Broken Porch Entry Stairs: 3 단계, 이미지 2개 중 2개
    • Use a measuring tape to measure the foundation where the new steps will be placed.
    • To ensure accurate measurements, make sure to repeat this step twice.
  4. How to Fix Broken Porch Entry Stairs: 4 단계, 이미지 3개 중 1개 How to Fix Broken Porch Entry Stairs: 4 단계, 이미지 3개 중 2개 How to Fix Broken Porch Entry Stairs: 4 단계, 이미지 3개 중 3개
    • Mark your measurements on both ends of your new weather treated wood using a measuring tape and a pencil.
    • For the best results, use a ruler to connect your marks into a straight line.
  5. How to Fix Broken Porch Entry Stairs: 5 단계, 이미지 1개 중 1개
    • Place the new piece of wood onto the end of a sturdy table.
    • Make sure the marked end is hanging off the edge by at least a foot.
  6. How to Fix Broken Porch Entry Stairs: 6 단계, 이미지 1개 중 1개
    • Use a circular saw to cut across the straight line marked on the new piece of wood.
    • Make sure the wood is secure by holding the end resting on the table the entire time.
    • Safety glasses should be worn during this step.
  7. How to Fix Broken Porch Entry Stairs: 7 단계, 이미지 2개 중 1개 How to Fix Broken Porch Entry Stairs: 7 단계, 이미지 2개 중 2개
    • Place the new piece of wood (riser) on the steps to ensure that it fits.
    • Use a leveler to make sure that it is level.
  8. How to Fix Broken Porch Entry Stairs: 8 단계, 이미지 3개 중 1개 How to Fix Broken Porch Entry Stairs: 8 단계, 이미지 3개 중 2개 How to Fix Broken Porch Entry Stairs: 8 단계, 이미지 3개 중 3개
    • Secure your wood piece (riser) into place using a drill and galvanized screws.
    • Create two pilot holes with the correct drill bit.
    • Secure the wood (riser) into place by drilling 2" galvanized Phillips head screws into the pilot holes.
  9. How to Fix Broken Porch Entry Stairs: 9 단계, 이미지 1개 중 1개
    • Make sure your wood piece (tread) fits into place and is level.
    • For the most accurate results, it is important to use a large level.
  10. How to Fix Broken Porch Entry Stairs: 10 단계, 이미지 3개 중 1개 How to Fix Broken Porch Entry Stairs: 10 단계, 이미지 3개 중 2개 How to Fix Broken Porch Entry Stairs: 10 단계, 이미지 3개 중 3개
    • Secure your wood piece (tread) into place using a drill and galvanized screws.
    • Create three pilot holes with the correct drill bit.
    • Secure the wood (tread) into place by drilling 2" galvanized Phillips head screws into the pilot holes.
  11. How to Fix Broken Porch Entry Stairs: 11 단계, 이미지 1개 중 1개
    • Repeat steps 8-10 for the remaining stairs.
    • For the best results, follow this guide thoroughly for each stair.
결론
To reassemble your old stairs, follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Kayla Unsworth
회원 가입일: 01/19/18
240 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 31
전체 시간: 9,492
