이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use a pry bar to remove the pre-existing damaged wood pieces.
Start with the riser first.
Remove the treads on the stairs.
Use a measuring tape to measure the foundation where the new steps will be placed.
Mark your measurements on both ends of your new weather treated wood using a measuring tape and a pencil.
Use a circular saw to cut across the straight line marked on the new piece of wood.
Place the new piece of wood (riser) on the steps to ensure that it fits.
Use a leveler to make sure that it is level.
Secure your wood piece (riser) into place using a drill and galvanized screws.
Create two pilot holes with the correct drill bit.
Secure the wood (riser) into place by drilling 2" galvanized Phillips head screws into the pilot holes.
Secure your wood piece (tread) into place using a drill and galvanized screws.
Create three pilot holes with the correct drill bit.
Secure the wood (tread) into place by drilling 2" galvanized Phillips head screws into the pilot holes.
다른 한 분이 해당 안내서를 완성하였습니다.
