주요 콘텐츠로 건너뛰기
How to Fix Broken Pottery Using Kintsugi
필요한 것
  1. How to Fix Broken Pottery Using Kintsugi, How to Fix Broken Pottery Using Kintsugi: 1 단계, 이미지 1/1
    • Clean the pottery with water and dry it with a towel.
  2. How to Fix Broken Pottery Using Kintsugi: 2 단계, 이미지 1/1
    • Combine the resin and the hardener in a container creating the epoxy.
    • Add 3 drops of each (resin and hardener).
  3. How to Fix Broken Pottery Using Kintsugi: 3 단계, 이미지 1/1
    • Use a craft stick to add the gold powder (Mica Powder) into the combination of resin and hardener.
    • Use a pinch of the Mica Powder.
  4. How to Fix Broken Pottery Using Kintsugi: 4 단계, 이미지 1/1
    • Stir the combination (epoxy and Mica Powder) with a tooth pick.
    • Make sure to not leave the combination (epoxy and Mica Powder) too long without stirring because it will begin to harden.
  5. How to Fix Broken Pottery Using Kintsugi: 5 단계, 이미지 1/1
    • Apply the combination (epoxy and Mica Powder) on one piece of the pottery.
    • Make sure one of the broken pieces is fully covered with the combination before placing the pieces together.
  6. How to Fix Broken Pottery Using Kintsugi: 6 단계, 이미지 1/1
    • Combine both pieces of pottery and allow the epoxy to dry for 5 minutes.
결승점
Hannah Rickman
회원 가입일: 03/22/23
133 평판
안내서 1개 작성함
University of Memphis, Team 14-4, Peters Spring 2023 University of Memphis, Team 14-4, Peters Spring 2023 회원
UM-PETERS-S23S14G4
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 198
