주요 콘텐츠로 건너뛰기
How to Fix Broken Pottery Using Kintsugi
필요한 것
  1. How to Fix Broken Pottery Using Kintsugi, How to Fix Broken Pottery Using Kintsugi: 1 단계, 이미지 1개 중 1개
    • Clean the pottery with water and dry it with a towel.
  2. How to Fix Broken Pottery Using Kintsugi: 2 단계, 이미지 1개 중 1개
    • Combine the resin and the hardener in a container creating the epoxy.
    • Add 3 drops of each (resin and hardener).
  3. How to Fix Broken Pottery Using Kintsugi: 3 단계, 이미지 1개 중 1개
    • Use a craft stick to add the gold powder (Mica Powder) into the combination of resin and hardener.
    • Use a pinch of the Mica Powder.
  4. How to Fix Broken Pottery Using Kintsugi: 4 단계, 이미지 1개 중 1개
    • Stir the combination (epoxy and Mica Powder) with a tooth pick.
    • Make sure to not leave the combination (epoxy and Mica Powder) too long without stirring because it will begin to harden.
  5. How to Fix Broken Pottery Using Kintsugi: 5 단계, 이미지 1개 중 1개
    • Apply the combination (epoxy and Mica Powder) on one piece of the pottery.
    • Make sure one of the broken pieces is fully covered with the combination before placing the pieces together.
  6. How to Fix Broken Pottery Using Kintsugi: 6 단계, 이미지 1개 중 1개
    • Combine both pieces of pottery and allow the epoxy to dry for 5 minutes.
결승점
작성자
1다른 기여자 명과 함께
Hannah Rickman
회원 가입일: 03/22/23
133 평판
안내서 1개를 작성함
1가이드 댓글
本ガイドで紹介されている手順は、一般的なエポキシ接着剤による金継ぎ手順とは異なるので注意して下さい。一般的な手順では、通常のエポキシ接着剤で外れた部品を接合し、接合部の凹凸を平らにしてから金色などに装飾する流れになります。
より具体的な手順については、最近公開された別の金継ぎ手順ガイドにまとまっていますので、そちらをご覧になることをお勧めします。
Servause - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 18
전체 시간: 423
