주요 콘텐츠로 건너뛰기
How to Fix Cat Scratches on a Leather Couch
필요한 것
  1. How to Fix Cat Scratches on a Leather Couch, How to Fix Cat Scratches on a Leather Couch: 1 단계, 이미지 3개 중 1개 How to Fix Cat Scratches on a Leather Couch, How to Fix Cat Scratches on a Leather Couch: 1 단계, 이미지 3개 중 2개 How to Fix Cat Scratches on a Leather Couch, How to Fix Cat Scratches on a Leather Couch: 1 단계, 이미지 3개 중 3개
    • Apply a small amount of the 50% isopropyl rubbing alcohol to a paper towel or cloth.
    • Wipe down the damaged area of the leather with the rubbing alcohol.
    • Refrain from rubbing too aggressively as this can further damage the couch.
  2. How to Fix Cat Scratches on a Leather Couch: 2 단계, 이미지 1개 중 1개
    • Move a spatula/scraper up and down over the scratches to determine the gradient (the way they open).
    • Opt for a plastic or rubber spatula rather than a metal one.
  3. How to Fix Cat Scratches on a Leather Couch: 3 단계, 이미지 3개 중 1개 How to Fix Cat Scratches on a Leather Couch: 3 단계, 이미지 3개 중 2개 How to Fix Cat Scratches on a Leather Couch: 3 단계, 이미지 3개 중 3개
    • Apply glue to the spatula/scraper and spread it over the damaged area on the couch.
    • Ensure the scratches are fully saturated in this step.
    • Refrain from pushing too hard with the tool as this can increase the size of the scratches.
  4. How to Fix Cat Scratches on a Leather Couch: 4 단계, 이미지 2개 중 1개 How to Fix Cat Scratches on a Leather Couch: 4 단계, 이미지 2개 중 2개
    • Push the spatula/scraper toward the gradient of the scratches, closing them, and removing excess glue.
    • Wait for the glue to fully dry before moving to the next step.
    • A hairdryer may be used in this step to speed up the drying process.
  5. How to Fix Cat Scratches on a Leather Couch: 5 단계, 이미지 3개 중 1개 How to Fix Cat Scratches on a Leather Couch: 5 단계, 이미지 3개 중 2개 How to Fix Cat Scratches on a Leather Couch: 5 단계, 이미지 3개 중 3개
    • Use the available colors in the dye kit with the paintbrush to spot-treat the repaired area.
    • Use light coats with this process for a clean and thorough application.
    • Let the product fully dry before moving to the next step.
    • This step can take 1-3 hours of waiting time for the product to dry.
    • Avoid touching the repaired area while it is drying.
  6. How to Fix Cat Scratches on a Leather Couch: 6 단계, 이미지 2개 중 1개 How to Fix Cat Scratches on a Leather Couch: 6 단계, 이미지 2개 중 2개
    • Before proceeding, you may use an 800-grit section of sandpaper to gently remove stiff or spiked remnants of color.
    • Apply 50% isopropyl alcohol to a paper towel or cloth.
    • Gently move over mistakes or areas with excess color.
    • The rubbing alcohol will remove more color if used in abundance or if too much pressure is applied during this step.
  7. How to Fix Cat Scratches on a Leather Couch: 7 단계, 이미지 2개 중 1개 How to Fix Cat Scratches on a Leather Couch: 7 단계, 이미지 2개 중 2개
    • The following steps are optional depending on the overall condition of the couch.
    • Apply a small amount of leather conditioner to a microfiber towel.
    • Work into the couch using circular motions, ensuring the product is massaged into the leather.
    • Depending on the location of the damage, allow 2-4 hours for the product to be absorbed into the leather before using the couch.
  8. How to Fix Cat Scratches on a Leather Couch: 8 단계, 이미지 1개 중 1개
    • Observe the finished product. Determine whether the leather surface is adequately scratch-free.
    • If the area needs more attention, repeat steps 1-7 accordingly.
결론
Once the dye has dried and the leather conditioner applied, the couch will be repaired to its former glory.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Sophia Boerner
회원 가입일: 02/20/24
189 평판
안내서 1개를 작성함
Arizona-Cools Stephens-S24S2G5 Arizona-Cools Stephens-S24S2G5 회원
Local Repair Groups
2 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 68
전체 시간: 1,192
