주요 콘텐츠로 건너뛰기
How to Fix Cracked Glassware with Food Safe Resin
필요한 것
  1. How to Fix Cracked Glassware with Food Safe Resin, How to Fix Cracked Glassware with Food Safe Resin: 1 단계, 이미지 1개 중 1개
    • Lay a garbage bag out on your workstation and put on disposable gloves.
    • Using separate cups, measure the resin and hardener to an exact 1:1 ratio.
    • Always wear gloves and ensure your work area is well-ventilated while working with resin. You may also want to wear safety glasses to protect your eyes.
  2. How to Fix Cracked Glassware with Food Safe Resin: 2 단계, 이미지 2개 중 1개 How to Fix Cracked Glassware with Food Safe Resin: 2 단계, 이미지 2개 중 2개
    • Add the resin and hardener to a container or bowl to mix the solution.
    • Scrape the sides of the measuring cups to ensure that both liquids are fully incorporated.
  3. How to Fix Cracked Glassware with Food Safe Resin: 3 단계, 이미지 1개 중 1개
    • Use the mixing stick to stir the resin and hardener for at least three minutes.
    • Scrape the sides and bottom while mixing.
  4. How to Fix Cracked Glassware with Food Safe Resin: 4 단계, 이미지 2개 중 1개 How to Fix Cracked Glassware with Food Safe Resin: 4 단계, 이미지 2개 중 2개
    • Dip one end of the Q-Tip into the resin mixture. Submerging is not necessary; ensure the tip is coated enough to cover the surface of the crack.
    • Apply the resin mixture to the affected area(s), covering the crack completely. Cover both the inside and outside of the crack if necessary.
    • Be careful of loose shards of glass.
  5. How to Fix Cracked Glassware with Food Safe Resin: 5 단계, 이미지 1개 중 1개
    • Allow the resin to cure for at least eight hours.
  6. How to Fix Cracked Glassware with Food Safe Resin: 6 단계, 이미지 2개 중 1개 How to Fix Cracked Glassware with Food Safe Resin: 6 단계, 이미지 2개 중 2개
    • Place the Q-tip and leftover resin into a disposable, sealable plastic bag.
    • Allow it to cure for 8+ hours before disposing.
    • Do NOT pour resin down the drain or into the sink.
    • Flip the measuring and mixing cups over the trash bag to remove any excess resin or hardener.
  7. How to Fix Cracked Glassware with Food Safe Resin: 7 단계, 이미지 2개 중 1개 How to Fix Cracked Glassware with Food Safe Resin: 7 단계, 이미지 2개 중 2개
    • When the resin has finished curing, use an alcohol wipe to remove any excess from the surface of your glass item.
    • If the resin is too hard, use a craft blade to gently scrape off the excess.
    • Exercise caution when working with blades.
  8. How to Fix Cracked Glassware with Food Safe Resin: 8 단계, 이미지 2개 중 1개 How to Fix Cracked Glassware with Food Safe Resin: 8 단계, 이미지 2개 중 2개
    • Pour warm water to ensure that the glassware is heat-safe and that the cracks are completely sealed.
    • Wash the glassware gently and thoroughly to remove any excess resin applied on the inside.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Hana
회원 가입일: 10/16/24
181 평판
안내서 1개를 작성함
1가이드 댓글
After applying resin, can I heat the item in open flame source ?
Jaggermeister Asti - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 35
지난 30일: 143
전체 시간: 1,319
