주요 콘텐츠로 건너뛰기
How to Fix D-Pad Sensitivity on Switch Pro Controller
필요한 것
  1. How to Fix D-Pad Sensitivity on Switch Pro Controller, Remove Left and Right Grip Screws: 1 단계, 이미지 1/3 How to Fix D-Pad Sensitivity on Switch Pro Controller, Remove Left and Right Grip Screws: 1 단계, 이미지 2/3 How to Fix D-Pad Sensitivity on Switch Pro Controller, Remove Left and Right Grip Screws: 1 단계, 이미지 3/3
    • The left and right grip screws are held in place with one J00 screw each. After the screw is removed, the grip slides straight off.
  2. How to Fix D-Pad Sensitivity on Switch Pro Controller, Removing the Back Plate: 2 단계, 이미지 1/2 How to Fix D-Pad Sensitivity on Switch Pro Controller, Removing the Back Plate: 2 단계, 이미지 2/2
    • Remove the four J00 screws holding the back plate in place.
    • Once they are removed, the back plate will just lift off with little to no force.
  3. How to Fix D-Pad Sensitivity on Switch Pro Controller, Removing Battery and Inner Plate: 3 단계, 이미지 1/3 How to Fix D-Pad Sensitivity on Switch Pro Controller, Removing Battery and Inner Plate: 3 단계, 이미지 2/3 How to Fix D-Pad Sensitivity on Switch Pro Controller, Removing Battery and Inner Plate: 3 단계, 이미지 3/3
    • The battery is super easy to remove! Thanks, Nintendo! Also, it's the same battery as what powers a 3DS (they're even interchangeable!) Neat!
    • Remove an additional J00 screw.
    • Remove an additional four J00 screws. The two in the battery bay are very easy to miss!
    • A closeup of the edge screws (also very easy to miss!).
  4. How to Fix D-Pad Sensitivity on Switch Pro Controller, Separating the Two Halves: 4 단계, 이미지 1/1
    • Use a pry tool or your fingernail to gently pull the two halves of the controller apart. Beware of the ribbon cable connecting the two boards!
    • This is a ZIF connector. The black tab on the connector pops straight up, allowing you to gently pull the cable straight out of the lock. I removed the cable from the board with the control sticks.
  5. How to Fix D-Pad Sensitivity on Switch Pro Controller, Removing the Shoulder Button Board: 5 단계, 이미지 1/1
    • Disconnect the ribbon cable that connects the plate to the controller board.
    • Afterward, remove two black J00 screws holding the plate onto the PCB.
  6. How to Fix D-Pad Sensitivity on Switch Pro Controller, Removing the D-Pad and Face Button Board: 6 단계, 이미지 1/1
    • Remove two more black J00 screws holding the board in place.
    • Reassembly tip: be very careful with the right screw, as it can crimp the ribbon cable if you're not careful!
  7. How to Fix D-Pad Sensitivity on Switch Pro Controller, Applying Tape for the Grand Finale!: 7 단계, 이미지 1/2 How to Fix D-Pad Sensitivity on Switch Pro Controller, Applying Tape for the Grand Finale!: 7 단계, 이미지 2/2
    • Voila! Here are the D-Pad touch sensors. I have outlined the area you want to cover in red.
    • Using tape (I recommend black electrical tape, but others have said it works with clear scotch or packing tape, just be aware it may pull up after a while and cause buttons to stick!), cover the highlighted areas. This really cuts down on accidental button presses.
    • After some testing, I applied the tape to the top and bottom touch connectors. This resulted in the smoothest operation with fewest accidental button presses. Always be sure to test (and make sure you like how it feels!) before you complete reassembly.
결론
To reassemble your (expensive) controller, simply follow these instructions in reverse order.
Hopefully, this guide was simple and easy to follow - just as the actual fix is. For my controller, it's night and day as far as sensitivity is concerned!
Have a great day and happy fixing!
다른 15명이 해당 안내서를 완성하였습니다.
Robbie Kincaid
회원 가입일: 04/23/19
547 평판
안내서 1개 작성함
댓글 13개
Thanks!! I got a bit confused on the 2nd ribbon cable because I wasn’t sure if it was a latch like the first but it worked out. Also reassembling the ribbon cables was a bit difficult and I wasn’t exactly sure how much I had to “plug” them in before closing the latch but I figured it out, thank you! Controller works wonderfully now.
Logan Henry - 답글
Glad to hear it! Thank you for your comment!
Robbie Kincaid -
Any issues using kapton tape instead of electrical tape?
Mirleis - 답글
Not to my knowledge (I don’t have any on hand to test with though). May be worth a shot!
Robbie Kincaid -
It should be noted that the official iFixit kit is recommended for the back screw removal (especially the ones at 11 and 1 o clock by the battery compartment) or you should have a screwdriver that is skinny enough to get it straight on. I barely got it with the iFixit kit and maybe left them a little bit loose because of that. Otherwise, this guide is very good for disassembling and cleaning.
Peter Fischbach - 답글
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 50
30일 전: 209
전체 시간: 14,242
