주요 콘텐츠로 건너뛰기
How to Fix Joy-Con Drift Without Disassembly
필요한 것
  1. How to Fix Joy-Con Drift Without Disassembly, How to Fix Joy-Con Drift Without Disassembly: 1 단계, 이미지 2개 중 1개 How to Fix Joy-Con Drift Without Disassembly, How to Fix Joy-Con Drift Without Disassembly: 1 단계, 이미지 2개 중 2개
    • Press and hold the black round button on the back of the Joy-Con, then slide it forward to remove.
  2. How to Fix Joy-Con Drift Without Disassembly: 2 단계, 이미지 2개 중 1개 How to Fix Joy-Con Drift Without Disassembly: 2 단계, 이미지 2개 중 2개
    • Open the 404B contact cleaner and insert the tube into the nozzle.
  3. How to Fix Joy-Con Drift Without Disassembly: 3 단계, 이미지 1개 중 1개
    • Push the Joy Stick to the side and hold.
  4. How to Fix Joy-Con Drift Without Disassembly: 4 단계, 이미지 2개 중 1개 How to Fix Joy-Con Drift Without Disassembly: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to lift the rubber ring under the Joy Stick, and hold.
  5. How to Fix Joy-Con Drift Without Disassembly: 5 단계, 이미지 2개 중 1개 How to Fix Joy-Con Drift Without Disassembly: 5 단계, 이미지 2개 중 2개
    • Aim the contact cleaner's nozzle at the gap and spray 404B contact cleaner once or twice.
  6. How to Fix Joy-Con Drift Without Disassembly: 6 단계, 이미지 3개 중 1개 How to Fix Joy-Con Drift Without Disassembly: 6 단계, 이미지 3개 중 2개 How to Fix Joy-Con Drift Without Disassembly: 6 단계, 이미지 3개 중 3개
    • Rotate the Joy Stick for 30 seconds to allow full penetration of the liquid inside.
  7. How to Fix Joy-Con Drift Without Disassembly: 7 단계, 이미지 1개 중 1개
    • Wait 10 minutes for the liquid to dry completely.
  8. How to Fix Joy-Con Drift Without Disassembly: 8 단계, 이미지 3개 중 1개 How to Fix Joy-Con Drift Without Disassembly: 8 단계, 이미지 3개 중 2개 How to Fix Joy-Con Drift Without Disassembly: 8 단계, 이미지 3개 중 3개
    • Insert the Joy-Con back into the Switch to test the Joy-Con.
    • Navigate to System Settings > Controllers and Sensors > Calibrate Control Sticks.
    • Follow the on-screen prompts on your Switch.
결론
Enjoy your Joy-Con being able to work properly again!
다른 36명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Weijie Chen
회원 가입일: 01/16/22
1,141 평판
안내서 1개를 작성함
2가이드 댓글
Process says it requires compressed air then goes on to use contact cleaner instead.
Mike Burr - 답글
댓글 쓰기
조회 통계:
지난 24시간: 82
지난 7일: 475
지난 30일: 2,217
전체 시간: 94,743
