소개
Water leaks for the Keurig B70 Brewing System are sometimes caused by an internal disconnection of the water pump and reservoir. Use this guide to open the Keurig and reseat the water pump.
도구
부품
부품은 필요하지 않습니다.
Move the brewer so that the metal baseplate is easily accessible.
Remove the five silver 4 mm Phillips #2 screws from the baseplate.
Remove the two silver 4mm Phillips #2 screws that hold the water pump in place.
다른 한 분이 해당 안내서를 완성하였습니다.
