주요 콘텐츠로 건너뛰기
How to Fix Loose Shirt Sleeves
필요한 것
  1. How to Fix Loose Shirt Sleeves, How to Fix Loose Shirt Sleeves: 1 단계, 이미지 1/3 How to Fix Loose Shirt Sleeves, How to Fix Loose Shirt Sleeves: 1 단계, 이미지 2/3 How to Fix Loose Shirt Sleeves, How to Fix Loose Shirt Sleeves: 1 단계, 이미지 3/3
    • Insert the holding pin downward through the fabric.
    • Insert the holding pin back over the fabric in an upward direction.
    • Be cautious as it is possible you may prick yourself if you hold it incorrectly.
    • Ensure that both holding pins are inserted in place to hold the fold.
    • Tie a knot at the end of your thread. We do this so that when you begin to sew, it does not weave out of its initial start.
  2. How to Fix Loose Shirt Sleeves: 2 단계, 이미지 1/3 How to Fix Loose Shirt Sleeves: 2 단계, 이미지 2/3 How to Fix Loose Shirt Sleeves: 2 단계, 이미지 3/3
    • Insert the sewing needle downward at the top of seam.
    • Insert the needle upward, towards you.
    • You can use your fingertips to help you pull the thread upward. You want to do this in a slow motion so that you do not risk tugging the initial thread too aggressively.
  3. How to Fix Loose Shirt Sleeves: 3 단계, 이미지 1/3 How to Fix Loose Shirt Sleeves: 3 단계, 이미지 2/3 How to Fix Loose Shirt Sleeves: 3 단계, 이미지 3/3
    • Reinsert the needle through the initial start of your hem.
    • Insert the needle upward, once more, through the second pierce you made.
    • This allows your thread to secure in place and creates the hemmed illusion.
    • You will repeat both the steps in the same order until you reach the end of your hem.
  4. How to Fix Loose Shirt Sleeves: 4 단계, 이미지 1/3 How to Fix Loose Shirt Sleeves: 4 단계, 이미지 2/3 How to Fix Loose Shirt Sleeves: 4 단계, 이미지 3/3
    • Repeat the directions in Step 3 to finalize the threading portion.
    • As you reach the final hemming point, you will have remaining thread.
  5. How to Fix Loose Shirt Sleeves: 5 단계, 이미지 1/3 How to Fix Loose Shirt Sleeves: 5 단계, 이미지 2/3 How to Fix Loose Shirt Sleeves: 5 단계, 이미지 3/3
    • Now that you identified your remaining thread, you will cut the thread at the tip of the needle. Again, handle carefully to avoid any finger puncture.
    • Grab both ends of the thread and bring together to form a halfway loop.
    • Tie a double knot tightly. Imagine you are tying a shoelace but only halfway.
    • You'll pull the knot tightly to secure in place.
  6. How to Fix Loose Shirt Sleeves: 6 단계, 이미지 1/3 How to Fix Loose Shirt Sleeves: 6 단계, 이미지 2/3 How to Fix Loose Shirt Sleeves: 6 단계, 이미지 3/3
    • After tying the knot, take the fabric scissors and cut off excess thread closest to the formed knot.
    • Repeat the last step for the excess thread at the initial sewing starting point.
    • You have completed your sleeve threading.
결론
Once you have selected your thread color (to match your article of clothing), you may begin the steps accordingly. The steps are repetitive from the beginning of your first sew, until the end.
Maggie J
회원 가입일: 09/17/23
133 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 5
30일 전: 25
전체 시간: 220
