주요 콘텐츠로 건너뛰기
How to Fix Loose Temples on Plastic Framed Reading Glasses
필요한 것
  1. How to Fix Loose Temples on Plastic Framed Reading Glasses, How to Fix Loose Temples on Plastic Framed Reading Glasses: 1 단계, 이미지 1/3 How to Fix Loose Temples on Plastic Framed Reading Glasses, How to Fix Loose Temples on Plastic Framed Reading Glasses: 1 단계, 이미지 2/3 How to Fix Loose Temples on Plastic Framed Reading Glasses, How to Fix Loose Temples on Plastic Framed Reading Glasses: 1 단계, 이미지 3/3
    • Fold the temples of the glasses inwards to feel which arm has less resistence.
  2. How to Fix Loose Temples on Plastic Framed Reading Glasses: 2 단계, 이미지 1/1
    • Locate the hinge screw on the arm that had less give.
    • The steps to replace the screw will be the exact same for both hinges.
  3. How to Fix Loose Temples on Plastic Framed Reading Glasses: 3 단계, 이미지 1/1
    • Test each screwdriver until the correct fit is found.
    • You may have to test every screwdriver to find the correct fit.
    • The screwdriver that we used was the #2 mm screwdriver.
  4. How to Fix Loose Temples on Plastic Framed Reading Glasses: 4 단계, 이미지 1/3 How to Fix Loose Temples on Plastic Framed Reading Glasses: 4 단계, 이미지 2/3 How to Fix Loose Temples on Plastic Framed Reading Glasses: 4 단계, 이미지 3/3
    • Insert the correct screwdriver into the screw and gently apply pressure.
    • Turn the screwdriver counterclockwise to unscrew the screw.
  5. How to Fix Loose Temples on Plastic Framed Reading Glasses: 5 단계, 이미지 1/1
    • Match the screw from the screwdriver kit.
    • Individually insert each screw into the eyeglasses. Different glasses use different screws.
  6. How to Fix Loose Temples on Plastic Framed Reading Glasses: 6 단계, 이미지 1/1
    • Insert the correct screwdriver into the screw.
  7. How to Fix Loose Temples on Plastic Framed Reading Glasses: 7 단계, 이미지 1/3 How to Fix Loose Temples on Plastic Framed Reading Glasses: 7 단계, 이미지 2/3 How to Fix Loose Temples on Plastic Framed Reading Glasses: 7 단계, 이미지 3/3
    • Turn the screwdriver clockwise to tighten.
    • Tighten the screw until you feel a slight resistance.
    • Do not over-tighten the screw.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
John
회원 가입일: 09/28/21
181 평판
안내서 1개 작성함
University of North Texas, Team 1-5, Raign Fall 2021 University of North Texas, Team 1-5, Raign Fall 2021 회원
UNT-RAIGN-F21S1G5
2 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 9
7일 전: 51
30일 전: 279
전체 시간: 7,929
