주요 콘텐츠로 건너뛰기
How to Fix Loose Temples on Plastic Framed Reading Glasses
필요한 것
  1. How to Fix Loose Temples on Plastic Framed Reading Glasses, How to Fix Loose Temples on Plastic Framed Reading Glasses: 1 단계, 이미지 3개 중 1개 How to Fix Loose Temples on Plastic Framed Reading Glasses, How to Fix Loose Temples on Plastic Framed Reading Glasses: 1 단계, 이미지 3개 중 2개 How to Fix Loose Temples on Plastic Framed Reading Glasses, How to Fix Loose Temples on Plastic Framed Reading Glasses: 1 단계, 이미지 3개 중 3개
    • Fold the temples of the glasses inwards to feel which arm has less resistence.
  2. How to Fix Loose Temples on Plastic Framed Reading Glasses: 2 단계, 이미지 1개 중 1개
    • Locate the hinge screw on the arm that had less give.
    • The steps to replace the screw will be the exact same for both hinges.
  3. How to Fix Loose Temples on Plastic Framed Reading Glasses: 3 단계, 이미지 1개 중 1개
    • Test each screwdriver until the correct fit is found.
    • You may have to test every screwdriver to find the correct fit.
    • The screwdriver that we used was the #2 mm screwdriver.
  4. How to Fix Loose Temples on Plastic Framed Reading Glasses: 4 단계, 이미지 3개 중 1개 How to Fix Loose Temples on Plastic Framed Reading Glasses: 4 단계, 이미지 3개 중 2개 How to Fix Loose Temples on Plastic Framed Reading Glasses: 4 단계, 이미지 3개 중 3개
    • Insert the correct screwdriver into the screw and gently apply pressure.
    • Turn the screwdriver counterclockwise to unscrew the screw.
  5. How to Fix Loose Temples on Plastic Framed Reading Glasses: 5 단계, 이미지 1개 중 1개
    • Match the screw from the screwdriver kit.
    • Individually insert each screw into the eyeglasses. Different glasses use different screws.
  6. How to Fix Loose Temples on Plastic Framed Reading Glasses: 6 단계, 이미지 1개 중 1개
    • Insert the correct screwdriver into the screw.
  7. How to Fix Loose Temples on Plastic Framed Reading Glasses: 7 단계, 이미지 3개 중 1개 How to Fix Loose Temples on Plastic Framed Reading Glasses: 7 단계, 이미지 3개 중 2개 How to Fix Loose Temples on Plastic Framed Reading Glasses: 7 단계, 이미지 3개 중 3개
    • Turn the screwdriver clockwise to tighten.
    • Tighten the screw until you feel a slight resistance.
    • Do not over-tighten the screw.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
John
회원 가입일: 09/28/21
199 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 18
지난 30일: 80
전체 시간: 11,020
