주요 콘텐츠로 건너뛰기
How to Fix Melted or Lumpy EOS Lip Balm
필요한 것
  1. How to Fix Melted or Lumpy EOS Lip Balm, How to Fix Melted or Lumpy EOS Lip Balm: 1 단계, 이미지 2개 중 1개 How to Fix Melted or Lumpy EOS Lip Balm, How to Fix Melted or Lumpy EOS Lip Balm: 1 단계, 이미지 2개 중 2개
    • To begin, open the lip-balm and use the knife to separate the center piece which holds the lip-balm in place from the bottom portion of the container.
    • Knives are sharp, and you need to apply some force to split the container from the grate. It is easier to wedge the knife by the little, square notch that would usually lock the EOS.
  2. How to Fix Melted or Lumpy EOS Lip Balm: 2 단계, 이미지 2개 중 1개 How to Fix Melted or Lumpy EOS Lip Balm: 2 단계, 이미지 2개 중 2개
    • Once they’ve been separated, remove the lip-balm from the center grate and place all pieces into the small microwavable bowl.
  3. How to Fix Melted or Lumpy EOS Lip Balm: 3 단계, 이미지 2개 중 1개 How to Fix Melted or Lumpy EOS Lip Balm: 3 단계, 이미지 2개 중 2개
    • Stirring every 10-15 seconds, microwave the bowl of balm until it reaches a liquid state.
    • Be sure to stir every 10-15 seconds. Balm that is left too long in the microwave will become dry and burned.
  4. How to Fix Melted or Lumpy EOS Lip Balm: 4 단계, 이미지 1개 중 1개
    • Immediately after removing the balm from the microwave, snap the middle grate into place on the top of the container this time
  5. How to Fix Melted or Lumpy EOS Lip Balm: 5 단계, 이미지 1개 중 1개
    • Pour the melted lip-balm through the grate and into the lid of the container in order to allow the balm to take shape of the container and to settle into the grate.
  6. How to Fix Melted or Lumpy EOS Lip Balm: 6 단계, 이미지 1개 중 1개
    • Place the open container in the fridge or freezer for approximately 10 minutes, or until the balm is hardened.
  7. How to Fix Melted or Lumpy EOS Lip Balm: 7 단계, 이미지 1개 중 1개
    • Once settled, remove from freezer and snap the bottom of the container firmly to put the pieces back together.
  8. How to Fix Melted or Lumpy EOS Lip Balm: 8 단계, 이미지 1개 중 1개
    • Twist open the container as usual; your lip-balm should be good as new!
결론
That's it! Enjoy your nice, smooth EOS.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Kate Hubbell
회원 가입일: 01/19/16
290 평판
안내서 1개를 작성함
Oakland University, Team 6-1, Walwema Winter 2016 Oakland University, Team 6-1, Walwema Winter 2016 회원
OAK-WALWEMA-W16S6G1
10 회원들
안내서 13개를 작성함
12가이드 댓글
WORKS GREAT! They don't sell these by me and I had picked up one in NYC last time I was there and fell in love with them. So, I ordered a 5 pack from Amazon and 3 of them came melted into the cap. I did exactly as the instructions said, and PERFECT! Thank you thank you thank you!!!
bobafett40 - 답글
Thank you soo much for posting this it actually worked thank you!!!
BOOYAKASHAKA - 답글
This was amazing it worked so well I wasn't sure it was going to work but then it came out looking brand spanking new!!!
Rolanda Williams - 답글
Does this technique work for the eos crystal?
Stacey Whittington - 답글
Does this technique work for smoothing out an eos crystal?
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 18
지난 30일: 119
전체 시간: 52,325
