주요 콘텐츠로 건너뛰기
How to Fix Oculus 2 Quest Controller Drift Without Disassembly
필요한 것
  1. How to Fix Oculus 2 Quest Controller Drift Without Disassembly, How to Fix Oculus 2 Quest Controller Drift Without Disassembly: 1 단계, 이미지 1개 중 1개
    • Remove the battery cover from the controller.
    • Remove the battery.
  2. How to Fix Oculus 2 Quest Controller Drift Without Disassembly: 2 단계, 이미지 2개 중 1개 How to Fix Oculus 2 Quest Controller Drift Without Disassembly: 2 단계, 이미지 2개 중 2개
    • Flip the straw up on the WD-40 for a pinpoint stream.
    • Make sure to use WD-40 specialist contact cleaner as opposed to traditional WD-40 which may damage your controller.
  3. How to Fix Oculus 2 Quest Controller Drift Without Disassembly: 3 단계, 이미지 3개 중 1개 How to Fix Oculus 2 Quest Controller Drift Without Disassembly: 3 단계, 이미지 3개 중 2개 How to Fix Oculus 2 Quest Controller Drift Without Disassembly: 3 단계, 이미지 3개 중 3개
    • Shake the can well for 20 to 30 seconds before each spray.
  4. How to Fix Oculus 2 Quest Controller Drift Without Disassembly: 4 단계, 이미지 1개 중 1개
    • Hold the joystick down in the opposite direction of the drift.
  5. How to Fix Oculus 2 Quest Controller Drift Without Disassembly: 5 단계, 이미지 1개 중 1개
    • Spray a small amount of the product into the joystick
    • It's important to use WD-40 specialist contact cleaner instead of the regular WD-40. It will break the controller if you use the wrong can.
  6. How to Fix Oculus 2 Quest Controller Drift Without Disassembly: 6 단계, 이미지 3개 중 1개 How to Fix Oculus 2 Quest Controller Drift Without Disassembly: 6 단계, 이미지 3개 중 2개 How to Fix Oculus 2 Quest Controller Drift Without Disassembly: 6 단계, 이미지 3개 중 3개
    • Wiggle the joystick around in circles to spread the residue.
    • Click the joystick down a couple of times.
  7. How to Fix Oculus 2 Quest Controller Drift Without Disassembly: 7 단계, 이미지 1개 중 1개
    • Wait for the the residue to dry for 3 minutes.
    • Replace the battery.
결승점
다른 12명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Adrian Sanchez
회원 가입일: 08/22/22
437 평판
안내서 1개를 작성함
CSU Los Angeles, Team 2-89, Briggs Fall 2022 CSU Los Angeles, Team 2-89, Briggs Fall 2022 회원
CSULA-BRIGGS-F22S2G89
1 회원
안내서 6개를 작성함
8가이드 댓글
In the article you warn the user:
"It's important to use WD-40 specialist contact cleaner instead of the regular WD-40. It will break the controller if you use the wrong can."
Are you referring to the "WD-40 Specialist ELECTRICAL Contact Cleaner" or just the "WD-40 Specialist Contact Cleaner?"
They're apparently two different products, with the former coming in a black/dark gray can (at twice the price) and the latter coming in the dark blue can that WD-40 has traditionally come in, and I don't want to pick up the wrong product for this.
Thanks for your time!
WafflesASAP - 답글
I feel that it being an electronic that it will use the electronic contact cleaner.
Francisco 1234 Cruz YT -
https://www.wd40.com/products/contact-cl... - The page indicates that they changed the appearance of the can, not the formulation. The two products you describe are the same one.
jon42 -
B and Y buttons no longer work after I used this method and fixed the stick drift.
Morgen Hoshi - 답글
Did not really work, didn’t even break the controller either, I should probably try again or something, also when I used the normal WD-40 it did not break anything but I am still suggesting to use the WD-40 specialist ELECTRICAL contact cleaner, have a nice day mate
ICameHereForWisdom - 답글
댓글 쓰기
조회 통계:
지난 24시간: 22
지난 7일: 86
지난 30일: 492
전체 시간: 28,678
