주요 콘텐츠로 건너뛰기
How to Fix Paper Jam in Canon Pixma TR 4520
필요한 것
  1. How to Fix Paper Jam in Canon Pixma TR 4520, press Stop to cancel the job: 1 단계, 이미지 1개 중 1개
    • push the stop button
  2. How to Fix Paper Jam in Canon Pixma TR 4520, turn off the printer and unplug it from the power source: 2 단계, 이미지 2개 중 1개 How to Fix Paper Jam in Canon Pixma TR 4520, turn off the printer and unplug it from the power source: 2 단계, 이미지 2개 중 2개
    • Press the turn off button on the printer before unplugging
  3. How to Fix Paper Jam in Canon Pixma TR 4520, remove any paper visible from the front tray: 3 단계, 이미지 2개 중 1개 How to Fix Paper Jam in Canon Pixma TR 4520, remove any paper visible from the front tray: 3 단계, 이미지 2개 중 2개
    • open the front tray and take a look
  4. How to Fix Paper Jam in Canon Pixma TR 4520, if it is accessible with your hands, pull out paper slowly with both hands(avoid tearing): 4 단계, 이미지 1개 중 1개
    • If paper tears apart, remove whatever you can, we can fix the rest in the later steps
  5. How to Fix Paper Jam in Canon Pixma TR 4520, if the area Is inaccessible or paper is torn, position the printer on a side to see the rear cover: 5 단계, 이미지 2개 중 1개 How to Fix Paper Jam in Canon Pixma TR 4520, if the area Is inaccessible or paper is torn, position the printer on a side to see the rear cover: 5 단계, 이미지 2개 중 2개
    • Do not force the paper out
  6. How to Fix Paper Jam in Canon Pixma TR 4520, pick up home usage screwdriver with the head like shown on the picture: 6 단계, 이미지 3개 중 1개 How to Fix Paper Jam in Canon Pixma TR 4520, pick up home usage screwdriver with the head like shown on the picture: 6 단계, 이미지 3개 중 2개 How to Fix Paper Jam in Canon Pixma TR 4520, pick up home usage screwdriver with the head like shown on the picture: 6 단계, 이미지 3개 중 3개
    • Take a look at the shape
  7. How to Fix Paper Jam in Canon Pixma TR 4520, look for two silver screws that hold transport unit cover from the rear end: 7 단계, 이미지 2개 중 1개 How to Fix Paper Jam in Canon Pixma TR 4520, look for two silver screws that hold transport unit cover from the rear end: 7 단계, 이미지 2개 중 2개
    • look at the circle annotation
  8. How to Fix Paper Jam in Canon Pixma TR 4520, untwist the screw, turn the screw into counter clockwise ("loose" direction) and keep turning the screwdriver: 8 단계, 이미지 3개 중 1개 How to Fix Paper Jam in Canon Pixma TR 4520, untwist the screw, turn the screw into counter clockwise ("loose" direction) and keep turning the screwdriver: 8 단계, 이미지 3개 중 2개 How to Fix Paper Jam in Canon Pixma TR 4520, untwist the screw, turn the screw into counter clockwise ("loose" direction) and keep turning the screwdriver: 8 단계, 이미지 3개 중 3개
    • Move the screwdriver slowly until the screw comes off
  9. How to Fix Paper Jam in Canon Pixma TR 4520, repeat for the second screw: 9 단계, 이미지 2개 중 1개 How to Fix Paper Jam in Canon Pixma TR 4520, repeat for the second screw: 9 단계, 이미지 2개 중 2개
    • Keep your screws in a safe place
  10. How to Fix Paper Jam in Canon Pixma TR 4520, transport unit cover will become loose: 10 단계, 이미지 2개 중 1개 How to Fix Paper Jam in Canon Pixma TR 4520, transport unit cover will become loose: 10 단계, 이미지 2개 중 2개
    • Be gentle while removing the unit, you don't want to damage it
  11. How to Fix Paper Jam in Canon Pixma TR 4520, remove the transport unit and reveal jammed paper: 11 단계, 이미지 3개 중 1개 How to Fix Paper Jam in Canon Pixma TR 4520, remove the transport unit and reveal jammed paper: 11 단계, 이미지 3개 중 2개 How to Fix Paper Jam in Canon Pixma TR 4520, remove the transport unit and reveal jammed paper: 11 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Take it out with your hands or if it is hard to grab on, pick up tweezers
  12. How to Fix Paper Jam in Canon Pixma TR 4520, put the transport unit back in its place and hold it there: 12 단계, 이미지 2개 중 1개 How to Fix Paper Jam in Canon Pixma TR 4520, put the transport unit back in its place and hold it there: 12 단계, 이미지 2개 중 2개
    • Grab your screwdriver and screws
  13. How to Fix Paper Jam in Canon Pixma TR 4520, put the screws back in place one at a time and turn them in clockwise direction to "tighten" them up: 13 단계, 이미지 3개 중 1개 How to Fix Paper Jam in Canon Pixma TR 4520, put the screws back in place one at a time and turn them in clockwise direction to "tighten" them up: 13 단계, 이미지 3개 중 2개 How to Fix Paper Jam in Canon Pixma TR 4520, put the screws back in place one at a time and turn them in clockwise direction to "tighten" them up: 13 단계, 이미지 3개 중 3개
    • You know it is tight enough if it doesn't move anymore
결승점
작성자
6다른 기여자 명과 함께
Ani Gurtsishvili
회원 가입일: 10/06/20
217 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 9
전체 시간: 1,075
