주요 콘텐츠로 건너뛰기
How to Fix Plastic Chair Cracks
필요한 것
  1. How to Fix Plastic Chair Cracks, How to Fix Plastic Chair Cracks: 1 단계, 이미지 2개 중 1개 How to Fix Plastic Chair Cracks, How to Fix Plastic Chair Cracks: 1 단계, 이미지 2개 중 2개
    • Lay the broken chair such that the crack is parallel to the floor.
  2. How to Fix Plastic Chair Cracks: 2 단계, 이미지 2개 중 1개 How to Fix Plastic Chair Cracks: 2 단계, 이미지 2개 중 2개
    • Wear gloves to minimize chemical contact on skin.
    • Dampen a rag with isopropyl alcohol.
  3. How to Fix Plastic Chair Cracks: 3 단계, 이미지 2개 중 1개 How to Fix Plastic Chair Cracks: 3 단계, 이미지 2개 중 2개
    • Clean the surface of the crack with the dampened rag to remove all dust and debris.
    • Repeat on all sides of the crack (edges and backside).
  4. How to Fix Plastic Chair Cracks: 4 단계, 이미지 3개 중 1개 How to Fix Plastic Chair Cracks: 4 단계, 이미지 3개 중 2개 How to Fix Plastic Chair Cracks: 4 단계, 이미지 3개 중 3개
    • Apply glue between the crack.
    • Then apply glue across the surface of the crack.
  5. How to Fix Plastic Chair Cracks: 5 단계, 이미지 1개 중 1개
    • Hold the two glued pieces together for 30 seconds to allow the glue to bind to the chair.
    • Do not let the glue dry completely. The wet glue will need to bind with baking soda in the next step.
  6. How to Fix Plastic Chair Cracks: 6 단계, 이미지 3개 중 1개 How to Fix Plastic Chair Cracks: 6 단계, 이미지 3개 중 2개 How to Fix Plastic Chair Cracks: 6 단계, 이미지 3개 중 3개
    • Pour baking soda over the crack until the glue is completely covered under a layer of baking soda.
  7. How to Fix Plastic Chair Cracks: 7 단계, 이미지 2개 중 1개 How to Fix Plastic Chair Cracks: 7 단계, 이미지 2개 중 2개
    • Use your finger to distribute the baking soda in order to cover all parts of the crack.
  8. How to Fix Plastic Chair Cracks: 8 단계, 이미지 3개 중 1개 How to Fix Plastic Chair Cracks: 8 단계, 이미지 3개 중 2개 How to Fix Plastic Chair Cracks: 8 단계, 이미지 3개 중 3개
    • Allow the baking soda to seal onto the super glue over the crack and wait for the mixture to dry.
    • After ten minutes, brush away some of the un-glued baking soda to check if the glue is solid.
  9. How to Fix Plastic Chair Cracks: 9 단계, 이미지 2개 중 1개 How to Fix Plastic Chair Cracks: 9 단계, 이미지 2개 중 2개
    • Flip the chair over.
    • Repeat the procedure on the backside of the crack starting from step 4 and ending with step 8.
    • Avoid reapplying glue in between crack, since it has already been sealed.
  10. How to Fix Plastic Chair Cracks: 10 단계, 이미지 2개 중 1개 How to Fix Plastic Chair Cracks: 10 단계, 이미지 2개 중 2개
    • Remove excess baking soda from both the front and back side of the crack.
    • Use water or isopropyl alcohol to remove fine grains around the repair site.
  11. How to Fix Plastic Chair Cracks: 11 단계, 이미지 1개 중 1개
    • Sand off any excess layers of glue on both the front and backside of the chair using coarse sandpaper.
    • This step is optional and simply helps to return the chair to its original look.
    • It may take a while to rid the chair of all texture.
  12. How to Fix Plastic Chair Cracks: 12 단계, 이미지 1개 중 1개
    • The crack has been repaired!
결승점
다른 18명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Sumeet Dhillon
회원 가입일: 02/18/20
529 평판
안내서 1개를 작성함
UC Davis, Team S2-G7, Andersen Winter 2020 UC Davis, Team S2-G7, Andersen Winter 2020 회원
UCD-ANDERSEN-W20S2G7
3 회원들
안내서 6개를 작성함
3가이드 댓글
Do you push the baking soda down into the glue (or into the crack), or just spread evenly on the surface?
Dr John Christensen - 답글
What glue did you use?
Raffaele Bianchi - 답글
Lem apa yang digunakan (nama lem)
Iwan Toro - 답글
댓글 쓰기
조회 통계:
지난 24시간: 20
지난 7일: 89
지난 30일: 468
전체 시간: 58,187
