주요 콘텐츠로 건너뛰기
How to Fix Scratches on a Steel Watch
필요한 것
  1. How to Fix Scratches on a Steel Watch, How to Fix Scratches on a Steel Watch: 1 단계, 이미지 1개 중 1개
    • Fill any container up with water.
  2. How to Fix Scratches on a Steel Watch: 2 단계, 이미지 1개 중 1개
    • Grab any soft-bristled brush around for your convenience.
  3. How to Fix Scratches on a Steel Watch: 3 단계, 이미지 3개 중 1개 How to Fix Scratches on a Steel Watch: 3 단계, 이미지 3개 중 2개 How to Fix Scratches on a Steel Watch: 3 단계, 이미지 3개 중 3개
    • Dip the toothbrush in the water.
    • Brush along the crystal, bezel, and case in a circular motion.
    • Brush the bracelet in a linear motion back-and-forth.
    • Make sure to brush over the crevices of the bracelet for an optimal clean.
  4. How to Fix Scratches on a Steel Watch: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Microfiber Cleaning Cloths
    $3.99
    • Dry the watch with a microfiber towel by pinching your fingers together in a back-and-forth motion.
  5. How to Fix Scratches on a Steel Watch: 5 단계, 이미지 1개 중 1개
    • Use the abrasive side of a sponge to brush the watch, following the same steps mentioned in Step 3.
    • Do not brush over the crystal with the sponge.
    • Apply minimal pressure to the sponge when brushing the watch.
  6. How to Fix Scratches on a Steel Watch: 6 단계, 이미지 1개 중 1개
    • Fold the metal polishing cloth in half.
    • Hold the corner of the cloth along your index finger.
  7. How to Fix Scratches on a Steel Watch: 7 단계, 이미지 1개 중 1개
    • Brush off all the scratches on the watch using a back-and-forth motion with great pressure to ensure effectiveness.
    • Perform the process as many times as needed.
    • Do not brush over the crystal.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Youssefmo
회원 가입일: 08/31/22
219 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 33
전체 시간: 1,096
