소개
This guide will help with fixing stripped screw holes from cabinet hinges, by securing those loose screws with anchors, a screwdriver, and a hammer.
Cabinets are held in place as long as their screws remain secured. However, with long term use of opening and closing cabinets, this results in a continual stress on the screws. This situation will create stripped screw holes, and it would be impossible to simply tighten the loose screws again. To simply solve this problem, just follow all the steps and the end result will be a nice and stable cabinet.
필요한 것
Use a screwdriver to remove the screws from the stripped holes.
Well done!
Well done!
다른 2명이 해당 안내서를 완성하였습니다.
댓글 2개
Boutje moertje door de wand is ook stevig
