주요 콘텐츠로 건너뛰기
How to Fix Stripped Screw Holes from Cabinet Hinges
필요한 것
  1. How to Fix Stripped Screw Holes from Cabinet Hinges, How to Fix Stripped Screw Holes from Cabinet Hinges: 1 단계, 이미지 3개 중 1개 How to Fix Stripped Screw Holes from Cabinet Hinges, How to Fix Stripped Screw Holes from Cabinet Hinges: 1 단계, 이미지 3개 중 2개 How to Fix Stripped Screw Holes from Cabinet Hinges, How to Fix Stripped Screw Holes from Cabinet Hinges: 1 단계, 이미지 3개 중 3개
    • Use a screwdriver to remove the screws from the stripped holes.
  2. How to Fix Stripped Screw Holes from Cabinet Hinges: 2 단계, 이미지 1개 중 1개
    • Take a screw from the cabinet hinge and use it to determine the appropriate size of screw anchor.
  3. How to Fix Stripped Screw Holes from Cabinet Hinges: 3 단계, 이미지 2개 중 1개 How to Fix Stripped Screw Holes from Cabinet Hinges: 3 단계, 이미지 2개 중 2개
    • Clear the screw holes of any debris.
  4. How to Fix Stripped Screw Holes from Cabinet Hinges: 4 단계, 이미지 2개 중 1개 How to Fix Stripped Screw Holes from Cabinet Hinges: 4 단계, 이미지 2개 중 2개
    • Place the screw anchors within each of the stripped screw holes.
  5. How to Fix Stripped Screw Holes from Cabinet Hinges: 5 단계, 이미지 2개 중 1개 How to Fix Stripped Screw Holes from Cabinet Hinges: 5 단계, 이미지 2개 중 2개
    • Secure the screw anchors within the hole by lightly tapping on them with a hammer.
    • Too much force can damage the anchor.
  6. How to Fix Stripped Screw Holes from Cabinet Hinges: 6 단계, 이미지 2개 중 1개 How to Fix Stripped Screw Holes from Cabinet Hinges: 6 단계, 이미지 2개 중 2개
    • Once the screw anchors are secured in place, align the cabinet hinges with the anchor holes.
    • Top of the anchor must fit tightly in the stripped hole.
  7. How to Fix Stripped Screw Holes from Cabinet Hinges: 7 단계, 이미지 3개 중 1개 How to Fix Stripped Screw Holes from Cabinet Hinges: 7 단계, 이미지 3개 중 2개 How to Fix Stripped Screw Holes from Cabinet Hinges: 7 단계, 이미지 3개 중 3개
    • Use a screwdriver and spin clockwise to screw the nail in place.
  8. How to Fix Stripped Screw Holes from Cabinet Hinges: 8 단계, 이미지 1개 중 1개
    • The screws are now secured, and the cabinet will no longer wobble.
결론
Well done!
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Richmond La
회원 가입일: 01/12/22
247 평판
안내서 1개를 작성함
York University, Team 2-13, O'Regan Winter 2022 York University, Team 2-13, O'Regan Winter 2022 회원
YORK-O'REGAN-W22S2G13
1 회원
안내서 4개를 작성함
2가이드 댓글
Boutje moertje door de wand is ook stevig
Aad Petersen - 답글
Wat also de gat te groot is. Moet je dan niet eerst gat vullen. Maar wat is handig, lijm of wax?
Nas sai - 답글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 93
지난 30일: 424
전체 시간: 36,203
