주요 콘텐츠로 건너뛰기
How to Fix Stuck Keys on the Rosewill NEON K51 Mechanical Keyboard
필요한 것
  1. How to Fix Stuck Keys on the Rosewill NEON K51 Mechanical Keyboard, Mem-chanical Key Switches: 1 단계, 이미지 1/1
    • Unplug the keyboard before beginning this guide.
    • Disconnecting the keyboard from its power supply will decrease the chance of any electrical discharge.
  2. How to Fix Stuck Keys on the Rosewill NEON K51 Mechanical Keyboard: 2 단계, 이미지 1/2 How to Fix Stuck Keys on the Rosewill NEON K51 Mechanical Keyboard: 2 단계, 이미지 2/2
    • Remove all keycaps that feel stuck or sticky with a keycap puller or similar tool.
    • Some keycaps may feel tough to pull off. Ensure that even force is applied to all contact points with the keycap and keycap puller.
  3. How to Fix Stuck Keys on the Rosewill NEON K51 Mechanical Keyboard: 3 단계, 이미지 1/1
    • Soak a cotton swab in alcohol.
    • Potential for device damage: Ensure that the cotton swab is not too damp. Excess alcohol may reach deep inside the keyboard housing, potentially damaging electrical components.
  4. How to Fix Stuck Keys on the Rosewill NEON K51 Mechanical Keyboard: 4 단계, 이미지 1/1
    • Clean the sides of the switch housing using the cotton swab.
    • Typically the surfaces of the switch stem, that come in contact with the housing, build up dirt that leads to keys feeling stuck or sticky. Pay close attention to these areas.
  5. How to Fix Stuck Keys on the Rosewill NEON K51 Mechanical Keyboard: 5 단계, 이미지 1/3 How to Fix Stuck Keys on the Rosewill NEON K51 Mechanical Keyboard: 5 단계, 이미지 2/3 How to Fix Stuck Keys on the Rosewill NEON K51 Mechanical Keyboard: 5 단계, 이미지 3/3
    • Reinstall the keycap. Line up the bottom of the keycap with the switch's housing. Verify a snug fit has been made.
  6. How to Fix Stuck Keys on the Rosewill NEON K51 Mechanical Keyboard: 6 단계, 이미지 1/1
    • Test the switch frequently by pressing down repeatedly with your finger.
    • This will help you gauge how well the alcohol is cleaning dirt build up.
  7. How to Fix Stuck Keys on the Rosewill NEON K51 Mechanical Keyboard: 7 단계, 이미지 1/1
    • Repeat until all switches have been cleaned and are feeling more responsive when pressed.
    • Between cleanings, ensure that the cotton swab remains moist but not too damp.
    • Potential for device damage: If a switch does not feel more responsive after two or three cleanings, do not continue to clean. Continued cleaning may result in excess alcohol reaching deep into the housing of the keyboard. This could lead to damaging electrical components.
  8. How to Fix Stuck Keys on the Rosewill NEON K51 Mechanical Keyboard: 8 단계, 이미지 1/1
    • Return all keycaps to their appropriate place on the keyboard. Pay close attention to the orientation of the letter of the keycap. Ensure that all keycaps are returned facing the correct direction.
    • Do not try to force a keycap back on to the switch. Ensure that the back of the keycap is properly aligned with the stem of the switch.
결론
Rosewell’s offering of “mem-chanical” keyboard switches are unique but not immune to dirt/grime build-up. You will find that cleaning the housing of theses switches will typically alleviate any sticky, or stuck, feeling keys.
Christopher Gonzales
회원 가입일: 02/19/21
157 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 28
전체 시간: 3,722
