주요 콘텐츠로 건너뛰기
How to Fix Subwoofer Amplifiers
필요한 것
  1. How to Fix Subwoofer Amplifiers, How to Fix Subwoofer Amplifiers: 1 단계, 이미지 1개 중 1개
    • Disconnect the black (negative) cable from the battery to disable the electrical connection.
    • Always disconnect the negative cable before the positive cable.
    • Disconnect the red (positive) cable from the battery to disable the electrical connection.
  2. How to Fix Subwoofer Amplifiers: 2 단계, 이미지 1개 중 1개
    • Pull the fuses out and make sure that they were not blown.
  3. How to Fix Subwoofer Amplifiers: 3 단계, 이미지 1개 중 1개
    • Undo and remove all wires from the amplifier.
    • This should include the battery wire, ground wire, speaker wires, remote wire from the radio, and sound wires that also come from radio.
    • Remove and check the fuse from the amp to make sure it is not a blown fuse.
  4. How to Fix Subwoofer Amplifiers: 4 단계, 이미지 1개 중 1개
    • Strip the wires so they can have a better connection.
    • Twist the exposed copper wiring to make it easier to connect to the amplifier.
  5. How to Fix Subwoofer Amplifiers: 5 단계, 이미지 1개 중 1개
    • Replace the wires in their designated slots.
    • Tighten the clamps all the way down.
    • Wiggle and tug on the wires to make sure they are secured nice and tight.
  6. How to Fix Subwoofer Amplifiers: 6 단계, 이미지 1개 중 1개
    • Replace the battery wires.
    • The red wire should go to the positive side, and the black wire should go to the negative side.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Luke Turner
회원 가입일: 03/23/23
154 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 59
전체 시간: 2,042
