주요 콘텐츠로 건너뛰기
How to Fix Thread Tension on a Juki DDL-8700
필요한 것
  1. How to Fix Thread Tension on a Juki DDL-8700, How to Fix Thread Tension on a Juki DDL-8700: 1 단계, 이미지 3개 중 1개 How to Fix Thread Tension on a Juki DDL-8700, How to Fix Thread Tension on a Juki DDL-8700: 1 단계, 이미지 3개 중 2개 How to Fix Thread Tension on a Juki DDL-8700, How to Fix Thread Tension on a Juki DDL-8700: 1 단계, 이미지 3개 중 3개
    • Thread the machine.
    • Insert the bobbin case.
  2. How to Fix Thread Tension on a Juki DDL-8700: 2 단계, 이미지 3개 중 1개 How to Fix Thread Tension on a Juki DDL-8700: 2 단계, 이미지 3개 중 2개 How to Fix Thread Tension on a Juki DDL-8700: 2 단계, 이미지 3개 중 3개
    • Sew a straight line on scrap fabric to test thread tension.
    • Be cautious when placing your fingers near the needle when working with the machine turned on.
  3. How to Fix Thread Tension on a Juki DDL-8700: 3 단계, 이미지 2개 중 1개 How to Fix Thread Tension on a Juki DDL-8700: 3 단계, 이미지 2개 중 2개
    • Check the fabric for loose thread tension.
    • Look out for loops of thread on the top and bottom of the fabric.
    • The bobbin case tension is too loose if loops are on the top of the fabric.
    • The upper thread tension is too loose if the loops are on the bottom of the fabric.
  4. How to Fix Thread Tension on a Juki DDL-8700: 4 단계, 이미지 2개 중 1개 How to Fix Thread Tension on a Juki DDL-8700: 4 단계, 이미지 2개 중 2개
    • Take out the bobbin case.
  5. How to Fix Thread Tension on a Juki DDL-8700: 5 단계, 이미지 3개 중 1개 How to Fix Thread Tension on a Juki DDL-8700: 5 단계, 이미지 3개 중 2개 How to Fix Thread Tension on a Juki DDL-8700: 5 단계, 이미지 3개 중 3개
    • Create a baseline thread tension for the bobbin case by tightening or loosening the screw on the bobbin case.
    • Thread should not easily unravel but can be pulled loosely.
  6. How to Fix Thread Tension on a Juki DDL-8700: 6 단계, 이미지 2개 중 1개 How to Fix Thread Tension on a Juki DDL-8700: 6 단계, 이미지 2개 중 2개
    • Reinsert the bobbin case into the machine.
  7. How to Fix Thread Tension on a Juki DDL-8700: 7 단계, 이미지 3개 중 1개 How to Fix Thread Tension on a Juki DDL-8700: 7 단계, 이미지 3개 중 2개 How to Fix Thread Tension on a Juki DDL-8700: 7 단계, 이미지 3개 중 3개
    • Sew another straight line on the scrap fabric next to the previous line.
  8. How to Fix Thread Tension on a Juki DDL-8700: 8 단계, 이미지 3개 중 1개 How to Fix Thread Tension on a Juki DDL-8700: 8 단계, 이미지 3개 중 2개 How to Fix Thread Tension on a Juki DDL-8700: 8 단계, 이미지 3개 중 3개
    • Check the front and back thread tension of the scrap fabric for loose stitches.
  9. How to Fix Thread Tension on a Juki DDL-8700: 9 단계, 이미지 3개 중 1개 How to Fix Thread Tension on a Juki DDL-8700: 9 단계, 이미지 3개 중 2개 How to Fix Thread Tension on a Juki DDL-8700: 9 단계, 이미지 3개 중 3개
    • Adjust the upper thread tension.
    • If there are loose stitches on the top of the fabric, loosen the upper thread tension by turning the tension knob counterclockwise.
    • If there are loose stitches on the bottom of the fabric, tighten the upper thread tension by turning the tension knob clockwise.
  10. How to Fix Thread Tension on a Juki DDL-8700: 10 단계, 이미지 3개 중 1개 How to Fix Thread Tension on a Juki DDL-8700: 10 단계, 이미지 3개 중 2개 How to Fix Thread Tension on a Juki DDL-8700: 10 단계, 이미지 3개 중 3개
    • Check the thread tension by sewing another straight line on the scrap fabric next to the previous line.
  11. How to Fix Thread Tension on a Juki DDL-8700: 11 단계, 이미지 3개 중 1개 How to Fix Thread Tension on a Juki DDL-8700: 11 단계, 이미지 3개 중 2개 How to Fix Thread Tension on a Juki DDL-8700: 11 단계, 이미지 3개 중 3개
    • The thread tension is correct if there are no loose stitches.
    • Repeat steps 5-8 as needed to achieve a consistent thread tension without loops on top or bottom of scrap fabric.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Brandon Mammon
회원 가입일: 11/05/24
214 평판
안내서 1개를 작성함
UC Davis, Team 1-9, Vidal-Chiesa Fall 2024 UC Davis, Team 1-9, Vidal-Chiesa Fall 2024 회원
UCD-VIDAL-CHIESA-F24S1G9
2 회원들
안내서 1개 작성
1가이드 댓글
اَلسَلامُ عَلَيْكُم وَرَحْمَةُ اَللهِ وَبَرَكاتُهُ‎
yar khan - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 17
지난 30일: 73
전체 시간: 872
