주요 콘텐츠로 건너뛰기
How to Fix Xbox 360 Controller Joystick Drift
필요한 것
  1. How to Fix Xbox 360 Controller Joystick Drift, How to Fix Stick Drift on Xbox 360 Controller: 1 단계, 이미지 1/2 How to Fix Xbox 360 Controller Joystick Drift, How to Fix Stick Drift on Xbox 360 Controller: 1 단계, 이미지 2/2
    • Remove seven screws from the back of the controller using a T8 Torx screwdriver.
  2. How to Fix Xbox 360 Controller Joystick Drift: 2 단계, 이미지 1/2 How to Fix Xbox 360 Controller Joystick Drift: 2 단계, 이미지 2/2
    • Remove the back to see the motherboard.
    • Do this with caution as it could easily be damaged if wires disconnect.
  3. How to Fix Xbox 360 Controller Joystick Drift: 3 단계, 이미지 1/2 How to Fix Xbox 360 Controller Joystick Drift: 3 단계, 이미지 2/2
    • Gently dab a cotton swab with isopropyl or rubbing alcohol to the joystick in a circular motion.
    • Be careful when adding liquid; too much liquid can damage the controller.
  4. How to Fix Xbox 360 Controller Joystick Drift: 4 단계, 이미지 1/2 How to Fix Xbox 360 Controller Joystick Drift: 4 단계, 이미지 2/2
    • Use a blow dryer to dry both the left and right joysticks.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Luis Ramirez
회원 가입일: 08/25/22
162 평판
안내서 1개 작성함
CSU Los Angeles, Team 9-6, Briggs Fall 2022 CSU Los Angeles, Team 9-6, Briggs Fall 2022 회원
CSULA-BRIGGS-F22S9G6
1 회원
안내서 5개 작성하였습니다
댓글 2개
This is not a genuine Xbox 360 controller and you truly aren't doing anything at all. You haven't even removed the thumbsticks to service the internals of the sensor assembly lol.
Alexander Dimitrov - 답글
Hi, I did this with a genuine controller and it completely worked for me. I just wiped the metal frames and went round the inside-joystick that I could, with the Q-tip.
ShadowNinja5764 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 48
7일 전: 309
30일 전: 1,179
전체 시간: 15,785
