주요 콘텐츠로 건너뛰기
How to Fix Xbox 360 Controller Joystick Drift
필요한 것
  1. How to Fix Xbox 360 Controller Joystick Drift, How to Fix Stick Drift on Xbox 360 Controller: 1 단계, 이미지 2개 중 1개 How to Fix Xbox 360 Controller Joystick Drift, How to Fix Stick Drift on Xbox 360 Controller: 1 단계, 이미지 2개 중 2개
    • Remove seven screws from the back of the controller using a T8 Torx screwdriver.
  2. How to Fix Xbox 360 Controller Joystick Drift: 2 단계, 이미지 2개 중 1개 How to Fix Xbox 360 Controller Joystick Drift: 2 단계, 이미지 2개 중 2개
    • Remove the back to see the motherboard.
    • Do this with caution as it could easily be damaged if wires disconnect.
  3. How to Fix Xbox 360 Controller Joystick Drift: 3 단계, 이미지 2개 중 1개 How to Fix Xbox 360 Controller Joystick Drift: 3 단계, 이미지 2개 중 2개
    • Gently dab a cotton swab with isopropyl or rubbing alcohol to the joystick in a circular motion.
    • Be careful when adding liquid; too much liquid can damage the controller.
  4. How to Fix Xbox 360 Controller Joystick Drift: 4 단계, 이미지 2개 중 1개 How to Fix Xbox 360 Controller Joystick Drift: 4 단계, 이미지 2개 중 2개
    • Use a blow dryer to dry both the left and right joysticks.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Luis Ramirez
회원 가입일: 08/25/22
288 평판
안내서 1개를 작성함
5가이드 댓글
This is not a genuine Xbox 360 controller and you truly aren't doing anything at all. You haven't even removed the thumbsticks to service the internals of the sensor assembly lol.
Alexander Dimitrov - 답글
Hi, I did this with a genuine controller and it completely worked for me. I just wiped the metal frames and went round the inside-joystick that I could, with the Q-tip.
ShadowNinja5764 - 답글
is replacing a joystick on a Xbox 360 wireless controller the same as replacing a joystick on a PowerA wired controller
batman2345 - 답글
Not sure, but i do know you need to be careful. The circuit board in the Xbox controller is very easy to damage. The pads can lift easily if not careful when desoldering. Add solder before you try to desolder.
Burned -
I believe this is a fix only for if you get premature stick drift. Stick drift from prolonged/intense use requires replacement of parts.
Wes Plants - 답글
댓글 쓰기
조회 통계:
지난 24시간: 30
지난 7일: 330
지난 30일: 1,282
전체 시간: 38,608
