주요 콘텐츠로 건너뛰기
How to Fix Xbox One Wireless Controller Drift
필요한 것
  1. How to Fix Xbox One Wireless Controller Drift, How to Fix Xbox One Wireless Controller Drift: 1 단계, 이미지 1개 중 1개
    • Remove the batteries from the controller.
    • If you are using a wired controller, disconnect the wire.
  2. How to Fix Xbox One Wireless Controller Drift: 2 단계, 이미지 3개 중 1개 How to Fix Xbox One Wireless Controller Drift: 2 단계, 이미지 3개 중 2개 How to Fix Xbox One Wireless Controller Drift: 2 단계, 이미지 3개 중 3개
    • Pour 90% isopropyl alcohol on the tip of a cotton ball.
    • Keep the item away from children and avoid touching your face and open wounds while using it.
  3. How to Fix Xbox One Wireless Controller Drift: 3 단계, 이미지 2개 중 1개 How to Fix Xbox One Wireless Controller Drift: 3 단계, 이미지 2개 중 2개
    • Rub the cotton ball all along the edges of the thumbstick.
  4. How to Fix Xbox One Wireless Controller Drift: 4 단계, 이미지 1개 중 1개
    • Let the controller dry for 40-60 seconds.
    • Repeat Steps 2-4 two more times or until the thumbstick no longer drifts.
  5. How to Fix Xbox One Wireless Controller Drift: 5 단계, 이미지 3개 중 1개 How to Fix Xbox One Wireless Controller Drift: 5 단계, 이미지 3개 중 2개 How to Fix Xbox One Wireless Controller Drift: 5 단계, 이미지 3개 중 3개
    • Connect your controller and see if there are any drift stick problems in any game. If the issue continues, then the next best option is to replace the joystick, and if that doesn't work, it's time to buy a new controller.
결론
After fixing the controller, if you run into the same problem more than a few times, the next best option I recommend would be to either replace the joystick or get an entirely new controller.
다른 15명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Julian Echevarria
회원 가입일: 01/25/22
450 평판
안내서 1개를 작성함
CSU Los Angeles, Team 4-76, Briggs Spring 2022 CSU Los Angeles, Team 4-76, Briggs Spring 2022 회원
CSULA-BRIGGS-S22S4G76
1 회원
안내서 8개를 작성함
11가이드 댓글
would hand sanitizer be a good substitute?
just me - 답글
Personally wouldn't recommend using hand sanitizer. IPA of various concentrations is already cheap and readily available in every pharmacy section, or a can of WD-40 Specialist Contact Cleaner is also around $5. In theory, hand sanitizer would "work" if it's ethanol/isopropyl alcohol based, but there's such a broad range of hand sanitizers, it would be irresponsible to make a blanket statement that they're all safe/unsafe for electronics. For example, many brands include fragrances, moisturizers, vitamin-E, etc. to keep your hands from excessively drying out, which can end up leaving residue and gumming up your electronics' contacts further.
SPARTAN VI -
I had actually been dumb enough not to look this up, so I just replaced the thumb sticks and it had made it better, but it didn't fix it. Any recommendations? I've had the controller since around 2016 or 2017. Original controller that came with the xbox.
Chill Doggo - 답글
The original Xbox one controller is notorious for getting stick drift. Only way to fix that one is the re-Solder the thumb stick back on. Like remove it and re-solder it.
Carlos Ramos -
THANK YOU!!!! Bruh….thank you.
Nick Ikombe - 답글
댓글 쓰기
조회 통계:
지난 24시간: 90
지난 7일: 504
지난 30일: 2,412
전체 시간: 216,897
