주요 콘텐츠로 건너뛰기
How to Fix Year and Model in About this Mac
  1. How to Fix Year and Model in About this Mac, Understanding How This Works: 1 단계, 이미지 2개 중 1개 How to Fix Year and Model in About this Mac, Understanding How This Works: 1 단계, 이미지 2개 중 2개
    • We first must understand how About this Mac shows the year and model.
    • The Mac will connect to Apple's database and send the Mac's serial number. It will then find using that serial number which Mac model you have and then show it in About this Mac.
    • The reason older versions of OS X no longer show the Mac model is because most of these versions can no longer connect to Apple's Server. Try going to apple.com, and you will probably get an error like the one in the picture.
  2. How to Fix Year and Model in About this Mac, Check Serial Number: 2 단계, 이미지 3개 중 1개 How to Fix Year and Model in About this Mac, Check Serial Number: 2 단계, 이미지 3개 중 2개 How to Fix Year and Model in About this Mac, Check Serial Number: 2 단계, 이미지 3개 중 3개
    • Check to make sure your serial number is valid.
    • Using a newer Mac, go to https://checkcoverage.apple.com
    • Enter the Mac's serial number (the one you are fixing, not the one with the webpage), and a code that Apple makes you put in.
    • If the Mac's year shows up, then you can fix the issue in About this Mac.
    • If the year does NOT show up, then your serial number is invalid, or your machine was specially built, and therefore About this Mac will not work anyway.
  3. How to Fix Year and Model in About this Mac, Fixing Issue With Keychain: 3 단계, 이미지 1개 중 1개
    • In order to fix this issue, we have to use Keychain.
    • Open Keychain by searching for it using Spotlight.
    • This will NOT make Apple's Website load, some versions of OS X are still too old to even load Apple's Website. This only allows the Mac to connect to Apple's Server, even if it can't load the webpage.
  4. How to Fix Year and Model in About this Mac: 4 단계, 이미지 2개 중 1개 How to Fix Year and Model in About this Mac: 4 단계, 이미지 2개 중 2개
    • In the sidebar, you will see "Certificates." Click that.
    • You will also see "System Roots." Click that as well.
    • A lot of certificates will show up.
  5. How to Fix Year and Model in About this Mac: 5 단계, 이미지 1개 중 1개
    • Type "apple" in the search bar.
  6. How to Fix Year and Model in About this Mac: 6 단계, 이미지 2개 중 1개 How to Fix Year and Model in About this Mac: 6 단계, 이미지 2개 중 2개
    • Now click on the first Certificate, and then click the "i" button in the bottom of the window.
    • Another window will appear.
  7. How to Fix Year and Model in About this Mac: 7 단계, 이미지 3개 중 1개 How to Fix Year and Model in About this Mac: 7 단계, 이미지 3개 중 2개 How to Fix Year and Model in About this Mac: 7 단계, 이미지 3개 중 3개
    • In the window that pops up, click the "Trust" tab.
    • Then click the box "When using this certificate." It will say "Use System Defaults" by default.
    • Now choose "Always Trust" instead.
  8. How to Fix Year and Model in About this Mac: 8 단계, 이미지 2개 중 1개 How to Fix Year and Model in About this Mac: 8 단계, 이미지 2개 중 2개
    • Close the window and enter your username and password to allow.
  9. How to Fix Year and Model in About this Mac: 9 단계, 이미지 1개 중 1개
    • Now repeat steps 5-7 for the rest of Apple's Certificates.
    • Your Mac may have more or less certificates than in the picture. This is fine.
    • Make sure you are only modifying Apple's Certificates. Modifying Third Party Certificates can lead to issues.
  10. How to Fix Year and Model in About this Mac, Checking Your Work: 10 단계, 이미지 1개 중 1개
    • Head back to About this Mac to see if the Year and Model show up.
  11. How to Fix Year and Model in About this Mac, Forcing a New Certificate: 11 단계, 이미지 1개 중 1개
    • If for some reason About this Mac still does not show the year, do not worry. There is one other thing you can do. You can force the Mac to make a new certificate.
    • To do this, click the "Support" tab in About this Mac.
    • Then choose "User Manual."
  12. How to Fix Year and Model in About this Mac: 12 단계, 이미지 2개 중 1개 How to Fix Year and Model in About this Mac: 12 단계, 이미지 2개 중 2개
    • A Safari window will open with a new error.
    • Click the "Show Certificate" button.
  13. How to Fix Year and Model in About this Mac: 13 단계, 이미지 2개 중 1개 How to Fix Year and Model in About this Mac: 13 단계, 이미지 2개 중 2개
    • Similar to before, choose "Trust,"
    • "When using this certificate,"
    • "Always Trust."
  14. How to Fix Year and Model in About this Mac: 14 단계, 이미지 2개 중 1개 How to Fix Year and Model in About this Mac: 14 단계, 이미지 2개 중 2개
    • Click Continue,
    • and enter your username and password to allow.
  15. How to Fix Year and Model in About this Mac: 15 단계, 이미지 1개 중 1개
    • Like I mentioned earlier, the webpage will not load even after forcing a new certificate.
  16. How to Fix Year and Model in About this Mac, Check Your Work Again: 16 단계, 이미지 1개 중 1개
    • Close all of the windows (including About this Mac).
    • Now open About this Mac again, and it should show you your Mac's year and model.
    • My Mac is a MacBook Air Early 2008 (Original)
결론
Hopefully this will have fixed the issue with your Mac. If for some reason this did not work, drop a comment down below.
작성자
1다른 기여자 명과 함께
Jadon Lyon
회원 가입일: 09/05/23
6,819 평판
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 9
지난 30일: 45
전체 시간: 532
