주요 콘텐츠로 건너뛰기
How to Fix a BIC Wite-Out Mini
필요한 것
  1. How to Fix a BIC Wite-Out Mini, How to Fix a BIC Wite-Out Mini: 1 단계, 이미지 1개 중 1개
    • Place the dispenser component with the logo facing down, with other components laid out on a clean, flat surface.
  2. How to Fix a BIC Wite-Out Mini: 2 단계, 이미지 1개 중 1개
    • Stabilize the small gear with tweezers to prevent further unwinding.
  3. How to Fix a BIC Wite-Out Mini: 3 단계, 이미지 3개 중 1개 How to Fix a BIC Wite-Out Mini: 3 단계, 이미지 3개 중 2개 How to Fix a BIC Wite-Out Mini: 3 단계, 이미지 3개 중 3개
    • Untangle the plastic strip by rotating the large gear in a circular motion, going in the opposite direction of the spiral.
    • Stop once the plastic strip connecting the gears is straight.
  4. How to Fix a BIC Wite-Out Mini: 4 단계, 이미지 3개 중 1개 How to Fix a BIC Wite-Out Mini: 4 단계, 이미지 3개 중 2개 How to Fix a BIC Wite-Out Mini: 4 단계, 이미지 3개 중 3개
    • Feed the plastic strip into the small gear until the white-out strip is visible.
    • Turn the big gear toward the small gear until they are close to each other.
  5. How to Fix a BIC Wite-Out Mini: 5 단계, 이미지 1개 중 1개
    • Place gears back into dispenser component with the logo.
    • Place the small gear onto the module closer to the dispensing slot.
    • Place the large gear onto module farthest from the dispensing slot.
  6. How to Fix a BIC Wite-Out Mini: 6 단계, 이미지 1개 중 1개
    • Hold the white-out strip with tweezers and pull to wrap the strip around the dispensing slot.
    • Make sure to stabilize the gears.
  7. How to Fix a BIC Wite-Out Mini: 7 단계, 이미지 3개 중 1개 How to Fix a BIC Wite-Out Mini: 7 단계, 이미지 3개 중 2개 How to Fix a BIC Wite-Out Mini: 7 단계, 이미지 3개 중 3개
    • Wrap the black band around both gears.
    • If necessary, stabilize the large gear with tweezers.
    • Wrap the band starting from large gear to small gear.
  8. How to Fix a BIC Wite-Out Mini: 8 단계, 이미지 2개 중 1개 How to Fix a BIC Wite-Out Mini: 8 단계, 이미지 2개 중 2개
    • Close the device until the side components click closed.
결론
Congrats! You have just successfully repaired your BIC Wite-Out Mini!
Test your BIC Wite-Out Mini to make sure that it works correctly. If it does not work, repeat steps 1-8 and try again!
작성자
3다른 기여자 명과 함께
Lauren Miller
회원 가입일: 01/31/24
157 평판
안내서 1개를 작성함
UC Davis, Team 3-1, Andersen Winter 2024 UC Davis, Team 3-1, Andersen Winter 2024 회원
UCD-ANDERSEN-W24S3G1
3 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 36
지난 30일: 146
전체 시간: 1,798
