주요 콘텐츠로 건너뛰기
How to Fix a Brazilian Hammock
필요한 것
  1. How to Fix a Brazilian Hammock, How to Fix a Brazilian Hammock: 1 단계, 이미지 1개 중 1개
    • Place the hammock on a flat surface.
    • Use scissors to cut the frayed ends from the damaged area.
  2. How to Fix a Brazilian Hammock: 2 단계, 이미지 2개 중 1개 How to Fix a Brazilian Hammock: 2 단계, 이미지 2개 중 2개
    • Align both sides of the tear leaving a quarter-inch gap between both sides of the tear.
    • Use safety pins to temporarily hold both sides of the tear together.
  3. How to Fix a Brazilian Hammock: 3 단계, 이미지 1개 중 1개
    • Cut a patch of the Ripstop fabric slightly larger than the tear.
  4. How to Fix a Brazilian Hammock: 4 단계, 이미지 1개 중 1개
    • Place the fabric on top of the tear and using safety pins temporarily hold the fabric to the hammock.
  5. How to Fix a Brazilian Hammock: 5 단계, 이미지 3개 중 1개 How to Fix a Brazilian Hammock: 5 단계, 이미지 3개 중 2개 How to Fix a Brazilian Hammock: 5 단계, 이미지 3개 중 3개
    • Be careful with the sewing needle. The end is very sharp.
    • Thread the needle and tie a knot at the end.
  6. How to Fix a Brazilian Hammock: 6 단계, 이미지 3개 중 1개 How to Fix a Brazilian Hammock: 6 단계, 이미지 3개 중 2개 How to Fix a Brazilian Hammock: 6 단계, 이미지 3개 중 3개
    • This step requires basic sewing skills but is easy to accomplish with time.
    • Use the threaded needle to sew from the bottom of the patch up and around the perimeter.
    • Make sure the needle and thread go through the patch and existing hammock material.
  7. How to Fix a Brazilian Hammock: 7 단계, 이미지 1개 중 1개
    • When finished tie a knot at the end of the stitch.
    • Make sure the knot is large enough, so it does not slip through the stitches.
  8. How to Fix a Brazilian Hammock: 8 단계, 이미지 2개 중 1개 How to Fix a Brazilian Hammock: 8 단계, 이미지 2개 중 2개
    • Remove all the safety pins and appreciate your work.
결론
This guide is now completed, enjoy your newly restored hammock.
작성자
1다른 기여자 명과 함께
Desiree Galvan
회원 가입일: 08/29/23
157 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 10
전체 시간: 274
