주요 콘텐츠로 건너뛰기
How to Fix a Broken Ceramic Vase
필요한 것
  1. How to Fix a Broken Ceramic Vase, How to Fix a Broken Ceramic Vase: 1 단계, 이미지 1/1
    • Examine the damage to the vase. Determine how large the cracks and chips are.
    • Smaller cracks can be fixed with a ceramic adhesive, while larger cracks may require putty.
  2. How to Fix a Broken Ceramic Vase: 2 단계, 이미지 1/1
    • Sand the broken edges and cracked pieces on the vase with a sander block.
  3. How to Fix a Broken Ceramic Vase: 3 단계, 이미지 1/2 How to Fix a Broken Ceramic Vase: 3 단계, 이미지 2/2
    • Apply ceramic adhesive to the broken pieces and press them together for two minutes.
  4. How to Fix a Broken Ceramic Vase: 4 단계, 이미지 1/1
    • Secure masking tape over the cracks and let the vase dry for 3 hours.
  5. How to Fix a Broken Ceramic Vase: 5 단계, 이미지 1/1
    • After the vase dries, clean the areas with a cloth where chunks of ceramic are missing.
  6. How to Fix a Broken Ceramic Vase: 6 단계, 이미지 1/2 How to Fix a Broken Ceramic Vase: 6 단계, 이미지 2/2
    • Use a chisel scraper to fill in the missing areas with putty and allow it to dry completely.
  7. How to Fix a Broken Ceramic Vase: 7 단계, 이미지 1/1
    • Select a paint that matches the vase and use a soft paintbrush to paint the dry putty wall.
  8. How to Fix a Broken Ceramic Vase: 8 단계, 이미지 1/1
    • Let the paint dry for one hour on the vase and your repair is finished.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Jennifer Ford
회원 가입일: 03/27/23
184 평판
안내서 1개 작성함
University of Memphis, Team 51-4, Peters Spring 2023 University of Memphis, Team 51-4, Peters Spring 2023 회원
UM-PETERS-S23S51G4
1 회원
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 30
30일 전: 142
전체 시간: 1,276
