주요 콘텐츠로 건너뛰기
How to Fix a Broken High Heel
필요한 것
  1. How to Fix a Broken High Heel, How to Fix a Broken High Heel: 1 단계, 이미지 2개 중 1개 How to Fix a Broken High Heel, How to Fix a Broken High Heel: 1 단계, 이미지 2개 중 2개
    • Peel back the sole of the heel.
    • This first step is if your heel has not completely broken off yet.
    • If it has broken off cleanly, proceed to Step 5.
  2. How to Fix a Broken High Heel: 2 단계, 이미지 2개 중 1개 How to Fix a Broken High Heel: 2 단계, 이미지 2개 중 2개
    • Remove the largest 10 x 1/2-inch stainless screw in the middle of the heel with a screwdriver.
  3. How to Fix a Broken High Heel: 3 단계, 이미지 1개 중 1개
    • Once the heel is broken off, use pliers to remove the four smaller 30 mm long, dia. 1.5 mm nails on the heel.
    • It’s alright if they bend and break. That is why we recommend buying extra nails.
  4. How to Fix a Broken High Heel: 4 단계, 이미지 1개 중 1개
    • Sand the heel down after removal of all the nails.
    • This will make the surface smoother for reattachment.
  5. How to Fix a Broken High Heel: 5 단계, 이미지 1개 중 1개
    • Align the heel back in place.
    • Use a hammer to reinsert the four smaller 30 mm long, dia. 1.5 mm nails.
  6. How to Fix a Broken High Heel: 6 단계, 이미지 1개 중 1개
    • Use a screwdriver to reinsert the largest middle 10 x 1/2" stainless steel screw into the heel.
  7. How to Fix a Broken High Heel: 7 단계, 이미지 2개 중 1개 How to Fix a Broken High Heel: 7 단계, 이미지 2개 중 2개
    • Now that the nails are all in place and the heel is secure, use leather repair glue to glue back the sole.
  8. How to Fix a Broken High Heel: 8 단계, 이미지 2개 중 1개 How to Fix a Broken High Heel: 8 단계, 이미지 2개 중 2개
    • Find any heavy object in your home, and lay it on top of the sole to make sure the glue settles.
결론
That concludes our guide we hope you have found this helpful.
작성자
3다른 기여자 명과 함께
Cindy Tan
회원 가입일: 02/03/23
157 평판
안내서 1개를 작성함
UC Davis, Team 1-2, Andersen Winter 2023 UC Davis, Team 1-2, Andersen Winter 2023 회원
UCD-ANDERSEN-W23S1G2
2 회원들
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 16
지난 30일: 76
전체 시간: 1,503
