주요 콘텐츠로 건너뛰기
How to Fix a Broken Loop in a Backpack
필요한 것
  1. How to Fix a Broken Loop in a Backpack, Locate the repair area: 1 단계, 이미지 2개 중 1개 How to Fix a Broken Loop in a Backpack, Locate the repair area: 1 단계, 이미지 2개 중 2개
    • Identify the loop that needs to be repaired.
  2. How to Fix a Broken Loop in a Backpack, Clean the area: 2 단계, 이미지 2개 중 1개 How to Fix a Broken Loop in a Backpack, Clean the area: 2 단계, 이미지 2개 중 2개
    • Use a seam ripper and a pair of scissors to completely remove the loop and get rid of any loose thread.
    • Tip: Once you have removed the loop, make sure you leave a space in the seam area to reinsert it later.
  3. How to Fix a Broken Loop in a Backpack, Start stitching: 3 단계, 이미지 3개 중 1개 How to Fix a Broken Loop in a Backpack, Start stitching: 3 단계, 이미지 3개 중 2개 How to Fix a Broken Loop in a Backpack, Start stitching: 3 단계, 이미지 3개 중 3개
    • Once you have removed the broken loop, stitch both ends together using a sewing machine.
  4. How to Fix a Broken Loop in a Backpack, Set the loop in place: 4 단계, 이미지 3개 중 1개 How to Fix a Broken Loop in a Backpack, Set the loop in place: 4 단계, 이미지 3개 중 2개 How to Fix a Broken Loop in a Backpack, Set the loop in place: 4 단계, 이미지 3개 중 3개
    • Introduce the stitched loop into the seam hole and hold it together with both hands.
  5. How to Fix a Broken Loop in a Backpack, Stitch the loop in place: 5 단계, 이미지 3개 중 1개 How to Fix a Broken Loop in a Backpack, Stitch the loop in place: 5 단계, 이미지 3개 중 2개 How to Fix a Broken Loop in a Backpack, Stitch the loop in place: 5 단계, 이미지 3개 중 3개
    • Following the last step, keep holding together the loop with both hands and gently place it on the sewing machine and start stitching.
    • Use a pair of scissors to clean the area and cut any loose threads.
  6. How to Fix a Broken Loop in a Backpack, Finished and ready!: 6 단계, 이미지 3개 중 1개 How to Fix a Broken Loop in a Backpack, Finished and ready!: 6 단계, 이미지 3개 중 2개 How to Fix a Broken Loop in a Backpack, Finished and ready!: 6 단계, 이미지 3개 중 3개
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
결론
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
작성자
1다른 기여자 명과 함께
Ben Blischke
회원 가입일: 07/19/23
10,230 평판
안내서 66개를 작성함
INTERSPORT INTERSPORT 회원
Community
25 회원들
안내서 169개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 20
전체 시간: 295
