주요 콘텐츠로 건너뛰기
How to Fix a Broken Necklace Chain
필요한 것
  1. How to Fix a Broken Necklace Chain, How to Fix a Broken Necklace Chain: 1 단계, 이미지 1/2 How to Fix a Broken Necklace Chain, How to Fix a Broken Necklace Chain: 1 단계, 이미지 2/2
    • Examine the break.
    • If there is an open link in the chain, skip to step three.
  2. How to Fix a Broken Necklace Chain: 2 단계, 이미지 1/3 How to Fix a Broken Necklace Chain: 2 단계, 이미지 2/3 How to Fix a Broken Necklace Chain: 2 단계, 이미지 3/3
    • Use the needle nosed pliers to separate the closure of a link on one side of the break.
    • You do not need this step if your necklace already has an open link.
  3. How to Fix a Broken Necklace Chain: 3 단계, 이미지 1/2 How to Fix a Broken Necklace Chain: 3 단계, 이미지 2/2
    • Hook the closed link opposite the break to the open link.
  4. How to Fix a Broken Necklace Chain: 4 단계, 이미지 1/3 How to Fix a Broken Necklace Chain: 4 단계, 이미지 2/3 How to Fix a Broken Necklace Chain: 4 단계, 이미지 3/3
    • Using the needle nosed pliers, squeeze the ends of the open link together.
    • Make sure the closed link is inside the open link.
  5. How to Fix a Broken Necklace Chain: 5 단계, 이미지 1/1
    • Using the needle nosed pliers, squeeze the closure so that the ends of the link are flush with one another.
  6. How to Fix a Broken Necklace Chain: 6 단계, 이미지 1/2 How to Fix a Broken Necklace Chain: 6 단계, 이미지 2/2
    • Test the closure by gently pulling it from either side. If it comes apart repeat steps 4 and 5.
결론
Now you're ready to flaunt your old necklace once again!
다른 35명이 해당 안내서를 완성하였습니다.
Bethany Smith
회원 가입일: 04/09/15
1,329 평판
안내서 2개 작성하였습니다
Cal Poly, Team 30-5, Green Spring 2015 Cal Poly, Team 30-5, Green Spring 2015 회원
CPSU-GREEN-S15S30G5
5 회원들
안내서 31개 작성하였습니다
댓글 12개
My chain broke when my 7 year old cousin pulled on it when he was piggy back ridding me. Ha Ha. Only took 20 min to do this. Very easy bit best to have nimble and dexterous fingers
Melvin Ricks - 답글
My very new chain had broken a day after my birthday .. and the chain is very special so of course I was panicking trying to figure out how to fix it . I found this website and i fixed it within 10 minutes.
Bethany - 답글
With the smaller necklaces, the broken link always falls off really easily, is there a way to make that easier to fix?
Angela Wei - 답글
My costly gold chain break down...as it is very lin... How can I joint it
Kunalsam 007 - 답글
I would like to say that my gold chain down due to its thinness...how can I joint this chain
Kunalsam 007 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 122
7일 전: 880
30일 전: 3,990
전체 시간: 446,108
