주요 콘텐츠로 건너뛰기
How to Fix a Broken Plastic Figurine
필요한 것
  1. How to Fix a Broken Plastic Figurine, How to Fix a Broken Plastic Figurine: 1 단계, 이미지 2개 중 1개 How to Fix a Broken Plastic Figurine, How to Fix a Broken Plastic Figurine: 1 단계, 이미지 2개 중 2개
    • Wipe down the figurine carefully with an alcohol wipe, focusing on the broken areas.
  2. How to Fix a Broken Plastic Figurine: 2 단계, 이미지 3개 중 1개 How to Fix a Broken Plastic Figurine: 2 단계, 이미지 3개 중 2개 How to Fix a Broken Plastic Figurine: 2 단계, 이미지 3개 중 3개
    • Plug in the hot glue gun and let it heat up.
    • Do not directly touch the tip of the hot glue gun.
    • Straighten out the paperclip.
    • Place the paperclip in the tip of the hot glue gun in order to heat the metal.
    • Allow the paperclip to heat up for 5 minutes.
  3. How to Fix a Broken Plastic Figurine: 3 단계, 이미지 1개 중 1개
    • Remove the paperclip from the glue gun.
    • Use the heated paperclip to scrape away excess material from one part of the figurine.
  4. How to Fix a Broken Plastic Figurine: 4 단계, 이미지 1개 중 1개
    • Firmly press the glue gun's heated tip into the other part of the figurine to melt the surrounding plastic for smoother placement.
  5. How to Fix a Broken Plastic Figurine: 5 단계, 이미지 2개 중 1개 How to Fix a Broken Plastic Figurine: 5 단계, 이미지 2개 중 2개
    • Align the broken pieces together carefully.
    • Press the two pieces together.
    • Hold together tightly for a minute to bond the pieces.
  6. How to Fix a Broken Plastic Figurine: 6 단계, 이미지 3개 중 1개 How to Fix a Broken Plastic Figurine: 6 단계, 이미지 3개 중 2개 How to Fix a Broken Plastic Figurine: 6 단계, 이미지 3개 중 3개
    • Apply tape to keep the pieces together.
    • Let it sit for 1 hour.
  7. How to Fix a Broken Plastic Figurine: 7 단계, 이미지 2개 중 1개 How to Fix a Broken Plastic Figurine: 7 단계, 이미지 2개 중 2개
    • Remove the tape top-down.
    • You're finished!
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jackson Smith
회원 가입일: 11/05/24
157 평판
안내서 1개를 작성함
UC Davis, Team 2-2, Vidal-Chiesa Fall 2024 UC Davis, Team 2-2, Vidal-Chiesa Fall 2024 회원
UCD-VIDAL-CHIESA-F24S2G2
3 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 16
지난 30일: 49
전체 시간: 373
