주요 콘텐츠로 건너뛰기
How to Fix a Broken Seam in a Camping Chair
필요한 것
  1. How to Fix a Broken Seam in a Camping Chair, Identify the repair area: 1 단계, 이미지 3개 중 1개 How to Fix a Broken Seam in a Camping Chair, Identify the repair area: 1 단계, 이미지 3개 중 2개 How to Fix a Broken Seam in a Camping Chair, Identify the repair area: 1 단계, 이미지 3개 중 3개
    • Locate the broken seam that needs to be fixed.
  2. How to Fix a Broken Seam in a Camping Chair, Unscrew the back of the chair: 2 단계, 이미지 3개 중 1개 How to Fix a Broken Seam in a Camping Chair, Unscrew the back of the chair: 2 단계, 이미지 3개 중 2개 How to Fix a Broken Seam in a Camping Chair, Unscrew the back of the chair: 2 단계, 이미지 3개 중 3개
    • Use a screwdriver to disassemble the back support and set aside the screws and remaining parts.
  3. How to Fix a Broken Seam in a Camping Chair, Clean the area: 3 단계, 이미지 3개 중 1개 How to Fix a Broken Seam in a Camping Chair, Clean the area: 3 단계, 이미지 3개 중 2개 How to Fix a Broken Seam in a Camping Chair, Clean the area: 3 단계, 이미지 3개 중 3개
    • Using a pair of scissors and a "seam ripper" remove the loose threads.
  4. How to Fix a Broken Seam in a Camping Chair, Start sewing: 4 단계, 이미지 3개 중 1개 How to Fix a Broken Seam in a Camping Chair, Start sewing: 4 단계, 이미지 3개 중 2개 How to Fix a Broken Seam in a Camping Chair, Start sewing: 4 단계, 이미지 3개 중 3개
    • Sew along the "dotted line" following the direction of the red arrow. This is the path where the previous stitch used to be.
    • Note: in this example, the original seam used to have 2 lines of stitches, this is why a second line of stitches is needed to reinforce the area.
  5. How to Fix a Broken Seam in a Camping Chair, Clean the loose threads: 5 단계, 이미지 2개 중 1개 How to Fix a Broken Seam in a Camping Chair, Clean the loose threads: 5 단계, 이미지 2개 중 2개
    • Using a pair of scissors cut the remaining threads to clean the area.
  6. How to Fix a Broken Seam in a Camping Chair, Reassemble the chair: 6 단계, 이미지 3개 중 1개 How to Fix a Broken Seam in a Camping Chair, Reassemble the chair: 6 단계, 이미지 3개 중 2개 How to Fix a Broken Seam in a Camping Chair, Reassemble the chair: 6 단계, 이미지 3개 중 3개
    • Start by putting the components back, first the repaired fabric and then the rest of the parts.
    • Tip: make sure the holes in the metal part of the chair match the holes of the fabric (orange circles).
    • Screw back the pieces that were taken on the previous steps.
  7. How to Fix a Broken Seam in a Camping Chair, Finished and ready!: 7 단계, 이미지 2개 중 1개 How to Fix a Broken Seam in a Camping Chair, Finished and ready!: 7 단계, 이미지 2개 중 2개
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
결론
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
작성자
1다른 기여자 명과 함께
Ben Blischke
회원 가입일: 07/19/23
10,230 평판
안내서 66개를 작성함
INTERSPORT INTERSPORT 회원
Community
25 회원들
안내서 169개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 15
전체 시간: 693
