주요 콘텐츠로 건너뛰기
How to Fix a Broken Seam on Pants
필요한 것
  1. How to Fix a Broken Seam on Pants, Locate the repair area: 1 단계, 이미지 3개 중 1개 How to Fix a Broken Seam on Pants, Locate the repair area: 1 단계, 이미지 3개 중 2개 How to Fix a Broken Seam on Pants, Locate the repair area: 1 단계, 이미지 3개 중 3개
    • Identify the part of the pants that needs repairing and gather all the necessary tools.
  2. How to Fix a Broken Seam on Pants, Pin the area: 2 단계, 이미지 3개 중 1개 How to Fix a Broken Seam on Pants, Pin the area: 2 단계, 이미지 3개 중 2개 How to Fix a Broken Seam on Pants, Pin the area: 2 단계, 이미지 3개 중 3개
    • Use sewing pines or needles to pin the seam area and hold it together for the next step.
  3. How to Fix a Broken Seam on Pants, Clean the area: 3 단계, 이미지 2개 중 1개 How to Fix a Broken Seam on Pants, Clean the area: 3 단계, 이미지 2개 중 2개
    • Once the area has been fixed with the pins, use a seam ripper to remove the old threads.
    • If there are still any remaining loose threads, use a pair scissors to cut them.
  4. How to Fix a Broken Seam on Pants, Start stitching: 4 단계, 이미지 3개 중 1개 How to Fix a Broken Seam on Pants, Start stitching: 4 단계, 이미지 3개 중 2개 How to Fix a Broken Seam on Pants, Start stitching: 4 단계, 이미지 3개 중 3개
    • Use a sewing machine to stitch the marked area.
    • Finish up the stitch by cutting any loose threads with a pair of scissors.
  5. How to Fix a Broken Seam on Pants, Finished and ready!: 5 단계, 이미지 3개 중 1개 How to Fix a Broken Seam on Pants, Finished and ready!: 5 단계, 이미지 3개 중 2개 How to Fix a Broken Seam on Pants, Finished and ready!: 5 단계, 이미지 3개 중 3개
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
결론
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
작성자
1다른 기여자 명과 함께
Ben Blischke
회원 가입일: 07/19/23
10,230 평판
안내서 66개를 작성함
INTERSPORT INTERSPORT 회원
Community
25 회원들
안내서 169개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 48
전체 시간: 601
