주요 콘텐츠로 건너뛰기
How to Fix a Broken Strap on a Strapback Hat
필요한 것
  1. How to Fix a Broken Strap on a Strapback Hat, How to Fix a Broken Strap on a Strapback Hat: 1 단계, 이미지 3개 중 1개 How to Fix a Broken Strap on a Strapback Hat, How to Fix a Broken Strap on a Strapback Hat: 1 단계, 이미지 3개 중 2개 How to Fix a Broken Strap on a Strapback Hat, How to Fix a Broken Strap on a Strapback Hat: 1 단계, 이미지 3개 중 3개
    • Measure the thread.
    • We recommend an arms-length amount of thread to ensure its enough to complete the fix without needing more thread.
    • Cut the thread at desired length.
  2. How to Fix a Broken Strap on a Strapback Hat: 2 단계, 이미지 2개 중 1개 How to Fix a Broken Strap on a Strapback Hat: 2 단계, 이미지 2개 중 2개
    • Thread the needle.
  3. How to Fix a Broken Strap on a Strapback Hat: 3 단계, 이미지 2개 중 1개 How to Fix a Broken Strap on a Strapback Hat: 3 단계, 이미지 2개 중 2개
    • Pull the thread through the needle until both ends of the thread meet.
    • Tie a knot at the end of the thread.
  4. How to Fix a Broken Strap on a Strapback Hat: 4 단계, 이미지 2개 중 1개 How to Fix a Broken Strap on a Strapback Hat: 4 단계, 이미지 2개 중 2개
    • Position the strap to where it was originally located on the hat.
  5. How to Fix a Broken Strap on a Strapback Hat: 5 단계, 이미지 2개 중 1개 How to Fix a Broken Strap on a Strapback Hat: 5 단계, 이미지 2개 중 2개
    • Ensure that the strap doesn't move by using a binder clip to hold it in place.
  6. How to Fix a Broken Strap on a Strapback Hat: 6 단계, 이미지 3개 중 1개 How to Fix a Broken Strap on a Strapback Hat: 6 단계, 이미지 3개 중 2개 How to Fix a Broken Strap on a Strapback Hat: 6 단계, 이미지 3개 중 3개
    • Starting on the inside of the hat, poke the needle through the cap and loose strap.
    • Pull the needle through the fabric and out the other end.
  7. How to Fix a Broken Strap on a Strapback Hat: 7 단계, 이미지 2개 중 1개 How to Fix a Broken Strap on a Strapback Hat: 7 단계, 이미지 2개 중 2개
    • Move the needle a few millimeters to the left and poke the needle through the front of the hat.
    • Pull the needle out on the other end.
  8. How to Fix a Broken Strap on a Strapback Hat: 8 단계, 이미지 2개 중 1개 How to Fix a Broken Strap on a Strapback Hat: 8 단계, 이미지 2개 중 2개
    • Repeat steps 6 and 7 until the strap is fully sewn onto the hat.
  9. How to Fix a Broken Strap on a Strapback Hat: 9 단계, 이미지 3개 중 1개 How to Fix a Broken Strap on a Strapback Hat: 9 단계, 이미지 3개 중 2개 How to Fix a Broken Strap on a Strapback Hat: 9 단계, 이미지 3개 중 3개
    • Tie a knot as close to the base of the hat as possible and cut the thread.
  10. How to Fix a Broken Strap on a Strapback Hat: 10 단계, 이미지 1개 중 1개
    • Your hat is fixed and ready to wear!
결론
Congratulations! With some simple hand sewing, you were able to fix the broken strap on your hat.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Sarah Sy
회원 가입일: 02/02/23
265 평판
안내서 1개를 작성함
UC Davis, Team 1-1, Andersen Winter 2023 UC Davis, Team 1-1, Andersen Winter 2023 회원
UCD-ANDERSEN-W23S1G1
3 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 64
지난 30일: 270
전체 시간: 8,536
