소개
How annoying is it to place your toilet paper in places other than its holder? Want to solve this issue? In this guide, we will look at how to fix a broken or loose toilet paper holder by replacing the drywall anchors with newer, better ones. The process is relatively simple, although it does require hand stability to drill the wall properly.
- It is optional to put a towel under the wall being drilled. This will help prevent drywall powder to fall on the floor.
- The screwdrivers used in this project fit the screws being used. Use the screwdriver according to the screws in possession.
필요한 것
As you can tell, the left holder is loose. Replacing the anchor is much needed.
거의 끝나갑니다!
결승점
다른 2명이 해당 안내서를 완성하였습니다.
