주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Fix a Broken Toilet Paper Holder
필요한 것
    1. How to Fix a Broken Toilet Paper Holder, How to Fix a Broken Toilet Paper Holder: 1 단계, 이미지 1개 중 1개
      • As you can tell, the left holder is loose. Replacing the anchor is much needed.
      댓글 쓰기
    2. How to Fix a Broken Toilet Paper Holder: 2 단계, 이미지 1개 중 1개
      • Remove the Allen screw under each holder.
      • I used a 1/6" Allen bit because that is what fit my toilet paper holder's Allen screw. Use the bit according to the screw available.
      • If the screw size is unknown, I would recommend buying a pack with several Allen bits and trying each until the right one is found.
      댓글 쓰기
    3. How to Fix a Broken Toilet Paper Holder: 3 단계, 이미지 3개 중 1개 How to Fix a Broken Toilet Paper Holder: 3 단계, 이미지 3개 중 2개 How to Fix a Broken Toilet Paper Holder: 3 단계, 이미지 3개 중 3개
      • After unscrewing the holder, take it off and begin unscrewing the screws in the wall. The type of screwdriver depends on the screws used.
      • Remove the clip after removing all screws. You should be left with two big holes and two small holes in the wall.
      댓글 쓰기
    4. How to Fix a Broken Toilet Paper Holder: 4 단계, 이미지 2개 중 1개 How to Fix a Broken Toilet Paper Holder: 4 단계, 이미지 2개 중 2개
      • Remove the existing anchor and drill the top hole with the 5/16" drill bit. This will make space for the new anchor to be placed.
      • Pinch the new 3/8"-1/2" anchor, place it into the top hole, and push it to be level with the wall.
      댓글 쓰기
    5. How to Fix a Broken Toilet Paper Holder: 5 단계, 이미지 2개 중 1개 How to Fix a Broken Toilet Paper Holder: 5 단계, 이미지 2개 중 2개
      • After placing the new anchor in, align the clip accordingly and proceed to screw in the anchor, starting with the top hole and then the bottom hole.
      • You have the option to use a either a screwdriver or drill (head based on the screws in possession).
      댓글 쓰기
    6. How to Fix a Broken Toilet Paper Holder: 6 단계, 이미지 2개 중 1개 How to Fix a Broken Toilet Paper Holder: 6 단계, 이미지 2개 중 2개
      • When you have completed the previous step for both sides, place the toilet paper holder in place and re-screw the Allen screw until both holders feel stiff.
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Andrew Nammour
회원 가입일: 07/05/20
229 평판
안내서 1개를 작성함
York University, Team S1-G9, Allen Summer 2020 York University, Team S1-G9, Allen Summer 2020 회원
YORK-ALLEN-SU20S1G9
1 회원
안내서 11개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 13
지난 7일: 44
지난 30일: 248
전체 시간: 30,034
