주요 콘텐츠로 건너뛰기
How to Fix a Broken Vertical Blind for Sliding Glass Door
필요한 것
  1. How to Fix a Broken Vertical Blind for Sliding Glass Door, How to Fix a Broken Vertical Blind for Sliding Glass Door: 1 단계, 이미지 1/2 How to Fix a Broken Vertical Blind for Sliding Glass Door, How to Fix a Broken Vertical Blind for Sliding Glass Door: 1 단계, 이미지 2/2
    • Remove the broken hanging blind slat from the holding piece at the top of the blind.
    • In this case, it was clear the slat was broken because there was tape needed to hold it on.
  2. How to Fix a Broken Vertical Blind for Sliding Glass Door: 2 단계, 이미지 1/2 How to Fix a Broken Vertical Blind for Sliding Glass Door: 2 단계, 이미지 2/2
    • Use scissors and cut the end of the slat just beneath the hole so it looks neater and a new hole can be made beneath it.
  3. How to Fix a Broken Vertical Blind for Sliding Glass Door: 3 단계, 이미지 1/2 How to Fix a Broken Vertical Blind for Sliding Glass Door: 3 단계, 이미지 2/2
    • Use a ruler and pencil and mark halfway in between the two long sides.
    • In this case, the mark was made at 1.75 inches from each side.
  4. How to Fix a Broken Vertical Blind for Sliding Glass Door: 4 단계, 이미지 1/2 How to Fix a Broken Vertical Blind for Sliding Glass Door: 4 단계, 이미지 2/2
    • Use the ruler and pencil again, and go along the center line, down about 3/8 inch and put a dot.
    • In this particular case, about 3/8 inches works best however it could vary depending on the blinds.
  5. How to Fix a Broken Vertical Blind for Sliding Glass Door: 5 단계, 이미지 1/2 How to Fix a Broken Vertical Blind for Sliding Glass Door: 5 단계, 이미지 2/2
    • Use the hole puncher and make a hole through the dot you just made on the blind slat.
  6. How to Fix a Broken Vertical Blind for Sliding Glass Door: 6 단계, 이미지 1/2 How to Fix a Broken Vertical Blind for Sliding Glass Door: 6 단계, 이미지 2/2
    • Replace the hanging slat back into the holding piece on the blinds.
    • Be careful in this step once again so as to not break the plastic piece or the newly fixed blind slat once again.
결론
Your vertical blinds are now fixed and hanging properly, looking brand new!
다른 2명이 해당 안내서를 완성하였습니다.
Andrew Sheedy
회원 가입일: 03/22/21
173 평판
안내서 1개 작성함
UMass Dartmouth, Team S2-G14, Riel Spring 2021 UMass Dartmouth, Team S2-G14, Riel Spring 2021 회원
UMASSD-RIEL-S21S2G14
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 24
30일 전: 143
전체 시간: 6,561
