주요 콘텐츠로 건너뛰기
How to Fix a Broken Water Pipe
필요한 것
  1. How to Fix a Broken Water Pipe, Joint: 1 단계, 이미지 1개 중 1개
    • Make sure the adapter fits the broken end of the water pipe by fitting the adapter without the sealing glue. (Just in case it is not the correct measurement.)
  2. How to Fix a Broken Water Pipe: 2 단계, 이미지 1개 중 1개
    • After reassuring it fits, apply waterproof sealant to both the pipe end and the adapters end.
    • The sealant glue goes on both ends, both the pipe’s and the adapter’s end.
  3. How to Fix a Broken Water Pipe: 3 단계, 이미지 1개 중 1개
    • Before the sealing glue dries out, insert the broken pipe to the adapter.
    • The glue dries very fast and if it does before placing the adapter on the pipe, it will not fit.
  4. How to Fix a Broken Water Pipe: 4 단계, 이미지 1개 중 1개
    • Hold the pipe in place firmly for a couple minutes until it is completely sealed and dry.
  5. How to Fix a Broken Water Pipe: 5 단계, 이미지 1개 중 1개
    • Apply sealing glue to the other side of the adapter and the water hose and insert it.
    • On this side, it may need more glue in order to prevent any leaking.
  6. How to Fix a Broken Water Pipe: 6 단계, 이미지 1개 중 1개
    • Hold it in place until it's completely dry.
    • It will help to push the hose as far in as it can go.
  7. How to Fix a Broken Water Pipe: 7 단계, 이미지 1개 중 1개
    • Make sure it does not leak on any of the sides.
    • Once you are sure it is completely dry, run water through the pipe to ensure there are no leaks.
  8. How to Fix a Broken Water Pipe: 8 단계, 이미지 1개 중 1개
    • Measure and cut hose to go wherever you need it to go.
    • For a better looking job, you can run the hose through all the corners so it is not that visible and it looks more professional.
결론
작성자
1다른 기여자 명과 함께
Lionexis Rodriguez
회원 가입일: 10/11/21
157 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 20
전체 시간: 1,076
