주요 콘텐츠로 건너뛰기
How to Fix a Broken Wooden Frame
필요한 것
  1. How to Fix a Broken Wooden Frame, How to Fix a Broken Wooden Frame: 1 단계, 이미지 1개 중 1개
    • Place the plastic sheet on the ground. Place ratchet straps on the sheeting. Lay the frame face down on top of the plastic sheeting. Dust off the area that is damaged.
    • Add glue to the crack.
  2. How to Fix a Broken Wooden Frame: 2 단계, 이미지 1개 중 1개
    • Push the glue in as far as you can.
    • Reapply if needed.
  3. How to Fix a Broken Wooden Frame: 3 단계, 이미지 1개 중 1개
    • Tighten the ratchet straps.
  4. How to Fix a Broken Wooden Frame: 4 단계, 이미지 2개 중 1개 How to Fix a Broken Wooden Frame: 4 단계, 이미지 2개 중 2개
    • Smooth out the glue.
  5. How to Fix a Broken Wooden Frame: 5 단계, 이미지 1개 중 1개
    • Wipe off any excess glue.
    • Allow to dry for 24 hours before undoing the ratchet straps.
  6. How to Fix a Broken Wooden Frame: 6 단계, 이미지 1개 중 1개
    • Measure 14 inches down from the top of the mirror to place the screw and loop found in the anchor kit.
  7. How to Fix a Broken Wooden Frame: 7 단계, 이미지 1개 중 1개
    • Use a power drill to screw in the screw and loop combo on both sides of the frame.
  8. How to Fix a Broken Wooden Frame: 8 단계, 이미지 1개 중 1개
    • Once both of the loops have been tightly screwed in, get an approximation of how much wire you will be using.
    • Put the wire through the loop with about 6" excess.
    • Place the anchors for the wall a few inches above the screws and slightly centered.
    • Pull taut on the wire where the anchors are and put the opposite end of the wire through the loop.
  9. How to Fix a Broken Wooden Frame: 9 단계, 이미지 2개 중 1개 How to Fix a Broken Wooden Frame: 9 단계, 이미지 2개 중 2개
    • With the wire through the loop, tie like a regular knot and give it a good tug.
  10. How to Fix a Broken Wooden Frame: 10 단계, 이미지 3개 중 1개 How to Fix a Broken Wooden Frame: 10 단계, 이미지 3개 중 2개 How to Fix a Broken Wooden Frame: 10 단계, 이미지 3개 중 3개
    • Feed the short end through the loop on the left side of the interior wire and pull tight.
    • Feed the short end through the loop but this time on the right side of the interior wire and pull tight. You are creating a slipknot.
    • Once the slipknot is tight, spin the excess wire around the interior wire like a coil for 1/2". Remove any excess with wire cutters.
  11. How to Fix a Broken Wooden Frame: 11 단계, 이미지 1개 중 1개
    • Measure 8" down to determine where the anchors will be placed on the wall.
    • Remove the ratchet straps.
  12. How to Fix a Broken Wooden Frame: 12 단계, 이미지 1개 중 1개
    • Drill one hole in the wall, and about 1/2" underneath that hole, drill another hole. It should be the same size and distance as the metal anchors.
  13. How to Fix a Broken Wooden Frame: 13 단계, 이미지 1개 중 1개
    • Insert the plastic anchors into each hole using a hammer.
    • Place the screw through the first hole in the metal anchor. Screw in the screw using the power drill.
    • Repeat for all four holes. Each hole should contain a plastic anchor and a screw.
  14. How to Fix a Broken Wooden Frame: 14 단계, 이미지 1개 중 1개
    • Align the mirror to the center of the metal anchor and hook the wire on.
결론
To unhook the mirror from the wall, follow these steps in reverse.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Tyler Turner
회원 가입일: 01/18/19
259 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 15
전체 시간: 4,709
