소개
The soldered connections in the average XLR cable can break under heavy use. Use this guide to disassemble an XLR connector and resolder the broken connection.
필요한 것
Place the end of the XLR Cable on a clean, uncluttered surface.
Using a small screwdriver, unscrew the single screw near the top of the cable.
Gently pull apart the exterior metal from the internal mechanism.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 한 개
Great repair. If the cabke is broken I have a video on resolving that issue. https://youtu.be/E8CiX4cnc-U
