주요 콘텐츠로 건너뛰기
How to Fix a Broken Zipper
필요한 것
  1. How to Fix a Broken Zipper, How to Fix a Broken Zipper: 1 단계, 이미지 1/3 How to Fix a Broken Zipper, How to Fix a Broken Zipper: 1 단계, 이미지 2/3 How to Fix a Broken Zipper, How to Fix a Broken Zipper: 1 단계, 이미지 3/3
    • Take the needle nose pliers and remove the metal or plastic stopper at the end of the zipper.
    • Zip the zipper all the way down to the last set of teeth.
  2. How to Fix a Broken Zipper: 2 단계, 이미지 1/3 How to Fix a Broken Zipper: 2 단계, 이미지 2/3 How to Fix a Broken Zipper: 2 단계, 이미지 3/3
    • Align both sides of the zipper evenly and slip the zipper back on track.
  3. How to Fix a Broken Zipper: 3 단계, 이미지 1/3 How to Fix a Broken Zipper: 3 단계, 이미지 2/3 How to Fix a Broken Zipper: 3 단계, 이미지 3/3
    • Start zipping up the zipper to make sure it has been aligned properly.
  4. How to Fix a Broken Zipper: 4 단계, 이미지 1/3 How to Fix a Broken Zipper: 4 단계, 이미지 2/3 How to Fix a Broken Zipper: 4 단계, 이미지 3/3
    • Thread the needle.
    • Sew up the area where the metal or plastic stopper used to reside.
  5. How to Fix a Broken Zipper: 5 단계, 이미지 1/3 How to Fix a Broken Zipper: 5 단계, 이미지 2/3 How to Fix a Broken Zipper: 5 단계, 이미지 3/3
    • Tie off what has been sewn by making a knot in the thread.
  6. How to Fix a Broken Zipper: 6 단계, 이미지 1/2 How to Fix a Broken Zipper: 6 단계, 이미지 2/2
    • Take the scissors and cut off the excess thread. Get as close to the knot as you can without cutting it off.
  7. How to Fix a Broken Zipper: 7 단계, 이미지 1/3 How to Fix a Broken Zipper: 7 단계, 이미지 2/3 How to Fix a Broken Zipper: 7 단계, 이미지 3/3
    • Zip up the garment to make sure everything is working properly.
결론
다른 10명이 해당 안내서를 완성하였습니다.
Katalina Holbrook
회원 가입일: 06/02/17
506 평판
안내서 1개 작성함
댓글 한 개
Not helpful. Suppose if the slider part broke and is now now. Now what?
Walter Nagel - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 15
30일 전: 78
전체 시간: 4,209
