주요 콘텐츠로 건너뛰기
How to Fix a Brother DCP-7060N Paper Jam
  1. How to Fix a Brother DCP-7060N Paper Jam, How to Fix a Brother DCP-7060N Paper Jam: 1 단계, 이미지 2개 중 1개 How to Fix a Brother DCP-7060N Paper Jam, How to Fix a Brother DCP-7060N Paper Jam: 1 단계, 이미지 2개 중 2개
    • Press the power button on the side of the printer to turn it off.
  2. How to Fix a Brother DCP-7060N Paper Jam: 2 단계, 이미지 1개 중 1개
    • Wait for ten minutes or until the printer has cooled down completely.
    • Touch the top cover to make sure the temperature has cooled down.
  3. How to Fix a Brother DCP-7060N Paper Jam: 3 단계, 이미지 2개 중 1개 How to Fix a Brother DCP-7060N Paper Jam: 3 단계, 이미지 2개 중 2개
    • Open the front tray carefully.
    • Check the status of the three rollers. If there is a paper jam, pull the paper out carefully.
  4. How to Fix a Brother DCP-7060N Paper Jam: 4 단계, 이미지 3개 중 1개 How to Fix a Brother DCP-7060N Paper Jam: 4 단계, 이미지 3개 중 2개 How to Fix a Brother DCP-7060N Paper Jam: 4 단계, 이미지 3개 중 3개
    • Pull two sides at the position in the photo to open the front cover.
    • Remove the drum from two sides in the position in the photo.
    • Draw out the toner at the photo position.
  5. How to Fix a Brother DCP-7060N Paper Jam: 5 단계, 이미지 1개 중 1개
    • Check inside if there is paper jam.
    • If there is a paper jam, carefully remove the paper with two hands and ensure there is nothing else inside.
  6. How to Fix a Brother DCP-7060N Paper Jam: 6 단계, 이미지 3개 중 1개 How to Fix a Brother DCP-7060N Paper Jam: 6 단계, 이미지 3개 중 2개 How to Fix a Brother DCP-7060N Paper Jam: 6 단계, 이미지 3개 중 3개
    • Turn the printer around.
    • Open the back cover of the printer at the position in photo.
    • Remove the back cover and check the status inside.
    • If there is a paper jam, take out the paper along the exit direction carefully.
  7. How to Fix a Brother DCP-7060N Paper Jam: 7 단계, 이미지 2개 중 1개 How to Fix a Brother DCP-7060N Paper Jam: 7 단계, 이미지 2개 중 2개
    • Close all covers and consumables bin.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
KehaoWu
회원 가입일: 01/15/22
224 평판
안내서 1개를 작성함
York University, Team S-30, Woodhouse Winter 2022 York University, Team S-30, Woodhouse Winter 2022 회원
YORK-WOODHOUSE-W22SSG30
1 회원
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 21
지난 30일: 81
전체 시간: 3,248
