주요 콘텐츠로 건너뛰기
How to Fix a Button on an Umbrella
필요한 것
  1. How to Fix a Button on an Umbrella, How to Fix a Button on an Umbrella: 1 단계, 이미지 1/1
    • Remove the 1.1 mm screw that fixates the handle to the umbrella using a Phillips #1 screwdriver.
  2. How to Fix a Button on an Umbrella: 2 단계, 이미지 1/2 How to Fix a Button on an Umbrella: 2 단계, 이미지 2/2
    • Remove the umbrella handle by pushing on the eject push-up button.
  3. How to Fix a Button on an Umbrella: 3 단계, 이미지 1/2 How to Fix a Button on an Umbrella: 3 단계, 이미지 2/2
    • Place a thin malleable metal in between the button’s connection to the metal projection.
  4. How to Fix a Button on an Umbrella: 4 단계, 이미지 1/2 How to Fix a Button on an Umbrella: 4 단계, 이미지 2/2
    • Apply permanent adhesive to secure the thin metal to the button's walls. Wait a few minutes for the adhesive to dry.
  5. How to Fix a Button on an Umbrella: 5 단계, 이미지 1/1
    • Verify that the button is firmly fixated to the metal ejector.
  6. How to Fix a Button on an Umbrella: 6 단계, 이미지 1/2 How to Fix a Button on an Umbrella: 6 단계, 이미지 2/2
    • Proceed to push down on the button while placing the handle.
    • The button goes through the handles button crevice.
  7. How to Fix a Button on an Umbrella: 7 단계, 이미지 1/1
    • Verify that the button is firmly fixated on the metal ejector.
  8. How to Fix a Button on an Umbrella: 8 단계, 이미지 1/1
    • Pound a nail with a hammer to prevent the opening system from turning.
  9. How to Fix a Button on an Umbrella: 9 단계, 이미지 1/1
    • Return the screw to fixate the handle to the umbrella.
결론
Maria Rosado
회원 가입일: 10/06/21
169 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 18
7일 전: 154
30일 전: 595
전체 시간: 15,736
