주요 콘텐츠로 건너뛰기
How to Fix a Cabinet Door Hinge with a Damaged Base
필요한 것
  1. How to Fix a Cabinet Door Hinge with a Damaged Base, Hinge: 1 단계, 이미지 1/3 How to Fix a Cabinet Door Hinge with a Damaged Base, Hinge: 1 단계, 이미지 2/3 How to Fix a Cabinet Door Hinge with a Damaged Base, Hinge: 1 단계, 이미지 3/3
    • Choose the correct screwdriver to remove the damaged hinge.
    • A properly sized bit should “fill up” the screw head, utilizing both the full depth and width of the socket.
    • In general, use the largest bit size that fits snugly into the screw.
  2. How to Fix a Cabinet Door Hinge with a Damaged Base: 2 단계, 이미지 1/3 How to Fix a Cabinet Door Hinge with a Damaged Base: 2 단계, 이미지 2/3 How to Fix a Cabinet Door Hinge with a Damaged Base: 2 단계, 이미지 3/3
    • If the door is still attach to the cabinet, use your screwdriver to remove the screws from the door hinges.
    • Take the doors off the cabinets before you begin the repair.
  3. How to Fix a Cabinet Door Hinge with a Damaged Base: 3 단계, 이미지 1/3 How to Fix a Cabinet Door Hinge with a Damaged Base: 3 단계, 이미지 2/3 How to Fix a Cabinet Door Hinge with a Damaged Base: 3 단계, 이미지 3/3
    • Remove all of the screws from the first hinge of the cabinet.
  4. How to Fix a Cabinet Door Hinge with a Damaged Base: 4 단계, 이미지 1/3 How to Fix a Cabinet Door Hinge with a Damaged Base: 4 단계, 이미지 2/3 How to Fix a Cabinet Door Hinge with a Damaged Base: 4 단계, 이미지 3/3
    • Remove all the the screws from the second hinge of the cabinet.
  5. How to Fix a Cabinet Door Hinge with a Damaged Base: 5 단계, 이미지 1/3 How to Fix a Cabinet Door Hinge with a Damaged Base: 5 단계, 이미지 2/3 How to Fix a Cabinet Door Hinge with a Damaged Base: 5 단계, 이미지 3/3
    • Remove all of the screws from the door hinge.
  6. How to Fix a Cabinet Door Hinge with a Damaged Base: 6 단계, 이미지 1/3 How to Fix a Cabinet Door Hinge with a Damaged Base: 6 단계, 이미지 2/3 How to Fix a Cabinet Door Hinge with a Damaged Base: 6 단계, 이미지 3/3
    • Squeeze the wood filler in the damaged base of the cabinet.
    • Some wood fillers require you to mix them with hardener. For those types, add 1/3 amount of hardener with filler and mix them until a consistent texture. Then apply the mixture to the damaged area. For more clarity, watch this video.
    • Place a card beside the hole and fill the hole with wood filler.
    • Overfill the damaged base slightly, to ensure the hole is filled completely.
  7. How to Fix a Cabinet Door Hinge with a Damaged Base: 7 단계, 이미지 1/3 How to Fix a Cabinet Door Hinge with a Damaged Base: 7 단계, 이미지 2/3 How to Fix a Cabinet Door Hinge with a Damaged Base: 7 단계, 이미지 3/3
    • Scrape the extra filler from the base with a putty knife or stiff card to smooth the surface before it dries.
    • Leave the filler for 20 to 30 minutes to dry.
  8. How to Fix a Cabinet Door Hinge with a Damaged Base: 8 단계, 이미지 1/3 How to Fix a Cabinet Door Hinge with a Damaged Base: 8 단계, 이미지 2/3 How to Fix a Cabinet Door Hinge with a Damaged Base: 8 단계, 이미지 3/3
    • Place the cabinet hinge repair plate on the new base and secure with the screws that are included in the kit.
    • Make sure the plate is properly aligned with existing holes.
  9. How to Fix a Cabinet Door Hinge with a Damaged Base: 9 단계, 이미지 1/3 How to Fix a Cabinet Door Hinge with a Damaged Base: 9 단계, 이미지 2/3 How to Fix a Cabinet Door Hinge with a Damaged Base: 9 단계, 이미지 3/3
    • Place the new cabinet hinge on the repair plate and screw it in with a drill.
    • Note that the size of hinges and screws may vary according to the individual's need.
  10. How to Fix a Cabinet Door Hinge with a Damaged Base: 10 단계, 이미지 1/3 How to Fix a Cabinet Door Hinge with a Damaged Base: 10 단계, 이미지 2/3 How to Fix a Cabinet Door Hinge with a Damaged Base: 10 단계, 이미지 3/3
    • If the base was only pulled out on one side, then simply screw the new hinge on the other side.
    • If the base was pulled out, use the wood filler technique and repair plate on both sides.
  11. How to Fix a Cabinet Door Hinge with a Damaged Base: 11 단계, 이미지 1/3 How to Fix a Cabinet Door Hinge with a Damaged Base: 11 단계, 이미지 2/3 How to Fix a Cabinet Door Hinge with a Damaged Base: 11 단계, 이미지 3/3
    • Using your screwdriver, attach the door to the cabinet.
    • Make sure the door is level and aligned with the other door.
  12. How to Fix a Cabinet Door Hinge with a Damaged Base: 12 단계, 이미지 1/1
    • Test the door multiple times by opening and closing it.
    • Congratulations, the door is now fixed!
결승점
다른 3명이 해당 안내서를 완성하였습니다.
Tayyaba Riasat
회원 가입일: 07/06/22
259 평판
안내서 1개 작성함
York University, Team M-24, Allen Summer 2022 York University, Team M-24, Allen Summer 2022 회원
YORK-ALLEN-SU22SMG24
1 회원
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 50
7일 전: 303
30일 전: 1,453
전체 시간: 18,606
